Evo III Water Pump Problem
Old Dec 25, 2008 | 06:57 PM
EvoIIIAj's Avatar
Everytime I turn off my car all the coolant leaks out from somewhere around the where the pump is. Anyone know what could be the cause of this?
Old Dec 25, 2008 | 07:11 PM
bvliz's Avatar
check the weep holes around the pump.seals might have went bad.i messed up my evo8 water pump from lifting the head acouple tmes.
Old Dec 26, 2008 | 08:42 AM
brucksport's Avatar
if you have fluid leakin from the little holes in the water pump,,,it time to get a new one,,,dont wait until it cost you an engine
Old Dec 26, 2008 | 06:13 PM
Bimmubishi's Avatar
It's either that, the gasket for the pump or the O ring between the pump and the water cross pipe.
Old Dec 26, 2008 | 08:58 PM
Broxma's Avatar
Evo III so old school DSM effectively. I may be wrong but I think the 5 bolts holding the pump on have different torque numbers. I have always despised the water pump on the G63. It's too easy to bend or fold the gasket when you put it on.
The crosspipe O-ring does get pretty crusty after it heat cycles a bunch of times. I have never had on S the bed on me but it's possible. I have also never been able to find a common source replacement for that O-ring. It is an odd size to my local parts store and they don't carry it.
/brox
Old Feb 26, 2009 | 06:27 PM
EvoIIIAj's Avatar
Was coming from the little holes...
I replaced it with a new OEM one last month..
Evodetailer123
Oct 6, 2016 01:09 PM
wallie123
Aug 10, 2016 11:53 AM
wallie123
Aug 4, 2016 06:53 PM
BoostNY
Apr 4, 2016 06:00 PM
redteam22003
Mar 22, 2008 02:40 AM
