Twin Tial BOV's?
Old Dec 29, 2008 | 06:28 AM
TiALSport's Avatar
Originally Posted by Motoxrider7
well im out of luck. lol unless i can build a 1000 hp evo and i dont have the money for that. that is really nice setup tho.
Arent the tial BOV's setup with psi springs? correct me if im wrong but what if you get twin bov setup each with small number of psi spring like 6 psi in each. that would be just like one 12 psi. or do i have the wrong idea
no, the 'psi' refers to vacuum, converting from psi to in/hg is 2.0x the psi, so if you pull -11in/hg you want the -6psi spring (which will open at -12in/hg)
2 TiAL bov's on anything less than say 1300whp is not necessary
on a 2200hp app, one Q is enough
Old Dec 29, 2008 | 09:50 AM
AWD Motorsports's Avatar
Just out of curiosity why does HP dictate how many BOV's you use?? A 700ci v8 running 15psi of boost making 2000hp surely wouldnt require what a 122ci running 80psi of boost making 1300hp would, correct?? Certain applications run Wastegates for BOV.. Some applications run NO BOV and 70psi of boost..
Old Dec 29, 2008 | 09:59 AM
SloRice's Avatar
Twin BOV's are for ricers...
Old Dec 29, 2008 | 10:06 AM
antilag_200's Avatar
^ my thoughts exactly
To the OP, if you want to read more about my theories feel free to pm me.
Tialsport--- I have found in my testing, that by heat stressing the springs, or even slight shimming of the spring, would drastically change the characteristics of the valve. Why is it that tial only sells springs in full # increments ?..Not bashing just simply asking.
Old Dec 29, 2008 | 04:35 PM
Motoxrider7's Avatar
Well ive read up about everything and i relize now why you run two. I was just sitting around wondering if anyone has ran twin bov's. Thanks for all the information. and im DEF not going to be running two. I have ONE tial.
Thanks guys.
Old Jan 2, 2009 | 12:50 AM
red evo8's Avatar
Originally Posted by BURNALL_4
EXCEPT for the fact that, thats just about the worst BOV on the face of the planet!!!
that actually depends on the car, i know many evos that run it vta no problem on stock maf. Many supras and srt's also run it with out problems and it holds boost fine. I prefer to defend parts that have proven themselves , like the hks ssqv.
Old Jan 2, 2009 | 04:27 AM
importjake00's Avatar
How do you figure it is a bad bov? On every car besides a evo it holds great boost and works just as well as any other bov.
Maybe the worst for a evo, but no worst then any other full VTA bov.
Old Jan 2, 2009 | 03:52 PM
ETS Michael's Avatar
We have build an upper intecooler pipe w/ twin TiALs for a couple customers. We only run one 50mm on our 1100hp car, but the old setup had two.
Check out the link below.
http://www.extremeturbosystems.com/D.../articles.html
Old Jan 3, 2009 | 08:22 PM
awdturbo8's Avatar
just keep one valve and call it a day. unless your going for looks..
_des_
Jun 3, 2016 11:38 AM
DSMdynamic
Mar 22, 2016 08:09 AM
RiioT
Nov 22, 2015 04:52 PM
Inline_X
Jul 19, 2012 03:36 PM
