Tial bov
Old Jun 27, 2012 | 09:07 AM
Inline_X's Avatar
Tial bov
Has anyone ever installed a tial bov without hooking up the vacuum line?
Old Jun 27, 2012 | 09:19 AM
Kracka's Avatar
Why in the world would you do that?
Old Jun 27, 2012 | 11:42 AM
Inline_X's Avatar
i just wanted to know if it was possible. i am having some issues with mine surging/flutter and i dont know if it is the spring inside or the vacuum line
Old Jun 27, 2012 | 11:46 AM
Kracka's Avatar
It needs the vacuum line to function properly. If it's adjustable, loosen it up a bit.
Old Jun 27, 2012 | 11:52 AM
Inline_X's Avatar
I am going to try replacing the spring one last time to a 10psi and see what happens then i will take it from there. if not i will maybe add a shim to the top of the BOV
Old Jun 28, 2012 | 12:00 PM
ben@importparts's Avatar
Where is the source of your vacuum?
Old Jul 15, 2012 | 07:07 AM
blasian760's Avatar
lol i hope no one would ever hook up a bov wit out the vac line !
Old Jul 19, 2012 | 03:32 PM
Snakes709's Avatar
theres your problem right there. Go to a -6psi spring...problem solved
Old Jul 19, 2012 | 03:36 PM
Anarchy99's Avatar
Tial valves typically have a flutter sound.. Why you would replace the stock metal one is the question you should be asking.
MisUnderStood
Jun 6, 2017 02:55 PM
_des_
Jun 3, 2016 11:38 AM
DSMdynamic
Mar 22, 2016 08:09 AM
RiioT
Nov 22, 2015 04:52 PM
