fp red vs fp green on pump results
this thread was created to help people like me on green with all the supporting mods , to see if its worth it to switch to fp red and u r only going to use pump 93 octane , on evereything else the fp red will beat the green , but on PUMP IS what we r looking for results .
any one on a red can teel me the difference in spool compared to the green ???
thanks to everyone supporting this thread and posting results ,
WOT spool up & transient spool-up are 2 different animals....being with a change in cam timing, you can get similar boost ramp up during a wot or dyno pull.
transient / initial low boost conditions is lower with the red, but its not bad...I dont want to give up transient response...the red is on the limit for me, when below 3000 rpm...being a bit on the numb side, relative to throttle input.
as far as power goes.....i ran 26/27 psi on 91 oct with the grn.....on the red i easily get away with 28psi through the whole rev range......calculated power numbers show a big gain in power for me.....i will be going on the dyno monday night to get some power #'s......all on 91 octane.
it comes down to the tune & how much boost 1 feels comfortable running.
not sure if this helps you. i will post my dyno numbers when i get them.
With regard to spool of the Green and Red this is what I have seen on the dyno
Evo Green - 2.1Bar at 3500
Evo Red - 2.0Bar at 3700
You really can't notice any difference on the road and the Red holds boost so much better
i have all the supporting mods , fully build motor etc,.. but i only plan on using pump on a red , alot of people have been switching to FP RED from a GREEN and have been dissapointed on PUMP , thats why i decided to create this thread to help out peolpe on making the right decitions ..on pump
red gives you space to grow. i love mine
i got 430 on pump @ 26psi full bolt ons with a conservative tune. on awdm dyno.
the car was fast. but then compared to being on E85 @30psi no contest.
