quick question
Old Jan 1, 2009 | 12:59 PM
Sansone's Avatar
quick question
Any difference between a stock evo 9 j-pipe and a stock evo 8 j pipe? or (outlet pipe, the little black one)
Old Jan 1, 2009 | 05:52 PM
MR_Evo_Rob's Avatar
I'm not familiar with the term J pipe. Where is it?
Old Jan 1, 2009 | 05:56 PM
ak47po's Avatar
more please.
Old Jan 1, 2009 | 05:57 PM
wevo1985's Avatar
i dont believe their is a difference between the 2 pipes. i used my stock evo 8 j-pipe on my fpgreen. i do know the lines are different between the 2 turbos.
Old Jan 1, 2009 | 05:58 PM
wevo1985's Avatar
the j-pipe is the first pipe off the turbo cold side. bolts right to the turbo.
Old Jan 1, 2009 | 06:01 PM
MR_Evo_Rob's Avatar
Ah. I'm pretty sure they are the same. But I've only seen an 8's one time and i don't remember it well. Looked a lot like mine.
Old Jan 1, 2009 | 07:02 PM
chaotichoax's Avatar
http://www.extremepsi.com/store/cust...cat=970&page=1
they are different
if you have an viii and want install a ix/green/red I believe you must have this
Old Jan 1, 2009 | 07:19 PM
tkevoixmr's Avatar
If i remember right the the VIII has the vacuum port on the actual turbo. The IX turbo has it on the J-Pipe. So, if you get rid of the VIII turbo, you have nowhere to hook up your boost control.
Old Jan 1, 2009 | 07:21 PM
markymark1082's Avatar
They are different
Old Jan 6, 2009 | 03:23 PM
Sansone's Avatar
thanks guys, do i need the oil lines as well or are they the same too?
Old Jan 6, 2009 | 07:08 PM
evo2005mr's Avatar
oil lines,,,water pipes...or just buy the install kit
Old Jan 6, 2009 | 07:56 PM
evolved0414's Avatar
The J-pipe is the pipe that bolts to the compressor side of the turbo. It connects right to the LICP.
Are you swaping out the 8 turbo for a 9?? because i just got done mine this past weekend.
Sansone's Avatar
ok thanks
Old Jan 7, 2009 | 03:14 PM
Sansone's Avatar
yes i am
seven10
Nov 29, 2016 09:42 PM
cerevo
Jul 15, 2015 10:53 AM
evolution666
Midwest Region
Jan 2, 2011 06:41 PM
tundeclips
Oct 8, 2010 05:03 PM
sharkm87
MitsubishiParts.net - WA
Mar 17, 2010 07:15 AM
