A few MIVEC tuning questions
Old Jan 2, 2009 | 10:46 AM
Kracka's Avatar
I have the IX FP4R cams in my car and am trying to better understand the MIVEC tuning aspect of them. My car has already been dyno-tuned but something in me says the car still has more in it. On FP's website they mention this:
"Best results will usually be had with the MIVEC map full advanced (94-96 degree lobe center) from 2500 - 5500rpm, then the lobe should be pulled back at the upper RPM. Full retard at the upper RPM is not usually the best way to go, we recommend trying 115-120 lobe centers at the highest RPM."
How do those degree lobe center numbers correlate to the values in the MIVEC table in ECUFlash (which I believe run from -1.2 to 28.8)? I know full advanced would be 28.8 and full retard is -1.2, but I'm unsure how to get the 115-120 lobe center they mention for the highest RPM range.
Thanks in advance for your help!
Old Jan 2, 2009 | 12:09 PM
JohnBradley's Avatar
Lobe center is the seperation (even split) between the intake centerline and the exhaust centerline.
nj1266
Jan 25, 2026 01:43 AM
EVOkeeper
Jun 22, 2014 08:43 PM
EvocentriK
Dec 19, 2012 06:03 PM
David Buschur
18
Mar 17, 2012 10:32 PM
RSMike
Nov 28, 2009 10:44 PM
