Lock the center diff
Old Jan 2, 2009 | 10:34 AM
LotusOmega439's Avatar
Does anyone know of a company that sells a part to lock the center diff so we can take out the front driveshaft and convert to RWD only? I know you can get this for the Subarus, but I think they are also available for the EVOs somewhere.
The diff we need to lock is a EVO 7, but probably the same as 8.
Old Jan 2, 2009 | 10:37 AM
Smike's Avatar
Rhys Millen was the only one I have seen.
Try contacting them.
http://www.rmrproducts.com/store/pc/home.asp
Old Jan 2, 2009 | 10:39 AM
AWD Motorsports's Avatar
The subaru has a RWD transmission so its easy to do.. I dont think it can be done on an evo w/o turning the motor around and using a RWD tranny..
Old Jan 2, 2009 | 10:43 AM
Curt@MrLed's Avatar
Former Vendor
Rhys is your only bet aside from welding the center diff.
Old Jan 2, 2009 | 10:44 AM
al3xx's Avatar
This may be a little OT, but I read somewhere that there's a modification to switch the FR torque balance from 50/50 to 30/70. Do you guys know anything about that?
Old Jan 2, 2009 | 10:52 AM
h22gordo's Avatar
Welding it sounds to be an easy solution.
Call RMR and ask Rhys if that is what they did.
Old Jan 2, 2009 | 11:04 AM
Jim in Tucson's Avatar
I looked into this once. As I recall Millen wants around $5,000 just for the parts. I'll try to find the email. Way too rich for my wallet.
The other problem with making an EVO into RWD is the huge amount of weight over the front wheels. A RWD EVO makes a Mustang or Carmaro look like a better balanced car.
YouTube it.
Old Jan 2, 2009 | 11:09 AM
We just need it to dyno an Opel with EVO drivetrain since we have only 2WD dyno. 5000USD for the parts is not even considered. Guess we need to rent another dyno for the job then.
Old Jan 2, 2009 | 11:10 AM
No, they actually machine some kind of adapter, or fitting, or whatever, that makes the EVO into a RWD. I'm assuming it is simply a replacement piece that no longer provides any power to the front wheels. Not sure if it actually has a proper name, since it is basically a one-off that they will produce on special order, as I understand it.
Old Jan 2, 2009 | 11:30 AM
sabastian458's Avatar
it has been done. look at the evo 9 in the toyko drift movie (yeah, i just refernced that damn movie) They were able to do the "adapter kit" to remove the front shafts. I only remember vaugely what was done to it, but i do know that it kept the evo engine and trans.
Old Jan 2, 2009 | 11:49 AM
Evo_Someday's Avatar
I'm sure your best, easiest, cheapest, and safest option will be to find an AWD dyno.
You can also "roughly" approximate the horsepower using a calculator if you know the 1/4 mile trap time and trap speed here -- http://www.dsm.org/tools/calchp.htm
Good luck.
Old Jan 2, 2009 | 01:42 PM
imbonez9's Avatar
on BR they have the adapter for make the 2g RWD. go and see if it will work or they have another thing for the Evo's
Old Jan 2, 2009 | 01:43 PM
the adapter buschur sells is so you can spin the motor around and attach a RWD tranny like a powerglide..
Old Jan 2, 2009 | 01:50 PM
CaliMR's Avatar
I saw an article in a magazine a couple years back, where they said how to do it yourself for way cheaper than the Millen thing. The problem was that it did not include the parts to allow more steering angle and it left the front axles etc. in place even though they were not connected. That should not matter if you are just popping it on the dyno. Try emailing import tuner and the other magazines like that, I forgot which one it was.
As for changing the split ratio like somebody else asked, you have to change the gears in the diff. There is a company that sells the gears, I think Cusco but I may be wrong. I am sure they are pretty pricey
Tyiler
Jan 9, 2016 11:07 AM
GoTopless
Aug 5, 2011 06:09 PM
lucky13evo
28
Jul 23, 2011 02:17 PM
eastxcelerate
14
Oct 18, 2010 12:18 PM
MATT@WORKS
23
Jan 12, 2008 10:51 AM
