Evo 9 Mr -Center Diff Oil Change
Old Jan 8, 2016 | 12:46 PM
Tyiler's Avatar
Did a Center Diff replacement on evo 9 from sheptrans, They instructed to use Redline for the center diff, Now I'm told to use Diaqueen only.
Can i switch over to diaqueen, what about the residue redline oil leftover in the diff? mix problems?
And if i can stay with redline, I forgot what kind, do you guys know what kinda of REDline I would need?
Why? Doing clutch replacement, (proper, so draining CDiff and dropping Subframe)
Old Jan 8, 2016 | 01:16 PM
LetsGetThisDone's Avatar
Transmission gets redline mt90, transfercase and rear diff get diaqueen.
Old Jan 9, 2016 | 08:57 AM
Tyiler's Avatar
Question
Do you think the redline int he TC is going to damage it? Also, how would you go about replacing the redline center diff fluid with Diaqueen ? (not put it in there in the first place XD) but seriously =3
Im worried about the residue mixxing with Diaqueen and causing foaming or some weird interaction between the two fluids, possibly causing damage the TC
Old Jan 9, 2016 | 11:07 AM
Just drain and fill, it won't he an issue mixing the little bit of redline with the diaqueen. If you're worried about it, do it twice with a short drive in between. It'll be fine.
evo9parts
Nov 5, 2017 02:47 PM
Kartracer550
Jul 3, 2013 11:26 AM
jameswwt
14
Feb 24, 2011 12:36 AM
Nasty Evolution
Oct 28, 2008 01:13 AM
evoturbo131
Aug 7, 2003 03:33 PM
