HFS-5, Maximum methanol to fuel ratio?
Old Jan 3, 2009 | 03:58 PM
darwin_evo's Avatar
Hello,
Planning to buy an HFS-5 wai kit. I'll use denatured alcohol, wich consists of 75% ethanol, 15% methanol and 10% water. So it's basically 90/10 alky/water. I'll use it either with the stock turbo or with the fp red.
My question is what's the maximum methanol to fuel ratio can i run with this kit??
Tks
Old Jan 3, 2009 | 05:26 PM
scheides's Avatar
EvoM Moderator
2x 1.0mm jets which would be about 27% if I'm not mistaken. More than enough to make awesome power!
Old Jan 3, 2009 | 05:30 PM
mt057's Avatar
you can run as much meth as you want. I run 100% meth. I get m1 from a local drag track that has it for 4.25 a gal. I have a 1mm and a .75-.8mm nozzles running at the same time.
Old Jan 4, 2009 | 03:52 AM
darwin_evo's Avatar
I heard that some people are running upto 50% methanol to fuel ratio, would that be possible, and how?
Tks
Old Jan 4, 2009 | 10:53 AM
mt057's Avatar
I would think that it would be a matter of simply leaning out your fuel injectors and compensating with methanol. I would recommend finding a tuner who is well versed and make sure that it would be safe/plausible.
Old Jan 4, 2009 | 12:01 PM
darwin_evo's Avatar
Well, my question is, is there any reason why i should not go above 30% methanol to fuel ratio?? any downsides for going upto 50%? (ie: atomization of the injected methanol ??)
Old Jan 4, 2009 | 04:05 PM
darwin_evo's Avatar
bump
Old Jan 4, 2009 | 11:45 PM
darwin_evo's Avatar
C'mon Methanol people
Old Jan 5, 2009 | 07:07 AM
SwiftEVO's Avatar
When I turn my meth on I have to pull about 33% of my fuel but Im running 2 m15 nozzles
--Josh
Old Jan 5, 2009 | 12:38 PM
darwin_evo's Avatar
Well You do have a 2.4L engine with a gt4088, I'm only intending to run it on a stock evo 9 turbo or fp red, so basically I'm not worried about the "physical" ability to run a 50% MFR, but rather about any problems that might occur from such a setup.
Anyone running 50/50 MFR?
Tks
Old Jan 5, 2009 | 12:41 PM
Evoryder's Avatar
What's meth?
Old Jan 5, 2009 | 01:32 PM
darwin_evo's Avatar
Hey Evoryder,
I see you are addicted to 100% methanol
What's your MFR??
Old Jan 5, 2009 | 04:46 PM
Evoryder's Avatar
Meth Fuel Ratio? 100%...
Old Jan 6, 2009 | 01:18 PM
darwin_evo's Avatar
Hehe, sweet
As i can see you have very good experience with meth, would you think a 50/50 MFR is possible when using HFS-5, by just mirroring the injectors?? (HFS-5 duty cycle to be the same as injectors duty cycle)
Tks
Old Jan 6, 2009 | 05:56 PM
Evoryder's Avatar
Yes you can tap into your factory injector duty. THis is actually one of the best ways of getting a linear consistent meth/water flow.
