info changin my clutch and what tools are need
Follow the evomoto link and you will be able to do it. Beware: There will be blood shed. The hardest part is by far getting the trans out and back in. Everything else is just very time consuming and annoying. Good luck!
You'll need to make a tool with a slide hammer and a bolt (weld bolt to slide hammer) to get a shaft out (kind of like an intermidate shaft that's between the tranny and transfer case). I'm not sure of the bolt size check the how-to for specifics. Also a crows foot prybar is really helpful for getting the driver's side axle out. You'll definitatly need an assortment of extensions and a swivel as well as a good toolset. As others have mentioned expect some blood letting.
It's not bad the only gay thing about it is the tob and make sure you have a slide hammer. Just bring your patience. And possibly a peroxide bottle/band aids if you're the clumsy type.
Tmosser
Jul 31, 2013 02:54 AM
CrackerJackToy
Sep 8, 2007 10:19 PM
kromix
Jul 13, 2003 07:58 AM
....i do have a lift and more that enough hands for the job and i wil have to look at that write up.....
