Timing Belt noise
Old Jan 8, 2009 | 08:07 AM
Doowop's Avatar
Timing Belt noise
Hey guys,
in the last few weeks my car started making a noise coming from belt area. I first thought it was a serpentine belt tensioner or one of the pulley. I took the serpentine belt out and checked the pulleys and tensioners and they are fine. The belt is good too. I ran the engine for a few second without the sepentine belt and the noise was still there. Seems to be coming from the armonic balancer area. I took it off and check it and it seems fine. I looked at the timing belt by rotating the engine and it seems to look good. I sprayed a little belt dressing on it, and the noise completely went away. It came back 2 days later. I am really not sure what could be wrong with the belt itself especially after only 13000 miles. any ideas? thanks. Car is a 06MR. I know it is still under warranty but a have a few mods and don't wanna get my warranty voided if it is an easy fix.
Old Jan 15, 2009 | 03:12 PM
Mitchubishievo's Avatar
I have the same exact issue. I found a thread a few weeks ago where someone said it was a pulley off angle or something of that sort. I hope someone in here can post and send us in the right direction.
Old Jan 15, 2009 | 03:22 PM
Slo_crx1's Avatar
The balance shaft belt rides on an idler pulley of sorts, as does the timing belt on the tensioner pulley. I'm not sure though how either of those 2 would cause any strange noises that would go away with some belt dressing, they basically roll on bearings. I could see if one of them got soaked with water and it ended up rusting the bearings a bit if it sat, it might make some weird noises.
Old Jan 16, 2009 | 10:59 AM
Drewsky06MR's Avatar
Smile Same issues also....
I have the exact same issue also. It is like this weird chuch, chuch, chuch sounds. I lifted the car and if your looking at the car from the front with it in the air, the noise is coming from the left back side. I also sprayed some lube on it and it went away. A few days later it was back!!! What is it!!! Please let me know if you have figured this out! Thnaks!
Old Feb 2, 2009 | 12:17 PM
Doowop's Avatar
I know for a fact the problem is from the timing belt itself or the timing belt pulleys. I was going to take it apart again, check it again, and spray a little again, but I doubt it will be a permanent fix. I guess, I am going ot have to try the dealer and hope they do not void my warranty.
Any of you guys resolved it?
orion4096
35
Jan 25, 2016 03:37 PM
bpdean
19
Dec 29, 2015 03:08 PM
delta6force94
Oct 31, 2015 08:24 AM
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
