bov question.
Old Jan 13, 2009 | 06:20 PM
alphadux_evo's Avatar
i got the same bov like yours and i ran it vta, so i cover the hole on the intake pipe but if you want to recirculate it you'll gonna have to get the recirculating kit.
Old Jan 14, 2009 | 12:18 AM
BadBoy818_818's Avatar
lol to me it looks like tho old owener used the stock bov as a cap to close the the intake whole instead of actually caping it but what do i knw im new at this too
Old Jan 14, 2009 | 05:22 AM
JakeTheVIII's Avatar
That's pretty funny. I guess it works though... Although weird looking, it works perfect as a cap for that hole. If you take it out, you will have problems driving and idling.
Old Jan 14, 2009 | 09:22 AM
triple_threat80's Avatar
I have been driving like this for almost eight months with no problems! The car idles fine no low boost bov flutter. Do you think i will cause problems like this or should i get it fixed asap. My only concern is i live right down the street from cobb tuning and im gonna be getting a accesport and a protune and the boost is gonna be turned up. is the stock bov gonna leak?
Old Jan 14, 2009 | 11:06 AM
if u really wanna fix it , dont close it up or cap it......put a tiny filter there it will do more good den harm , but im pretty sure that a bov as a cap would be very secure i mean have u ever actually tried pushing on that thing with your finger?strong *** hell so your good
Old Jan 14, 2009 | 11:09 AM
never mind i take back wat i said about the tiny filter i forgot about the sensor thingy on the intake .......... it will idle i guess if u put a filter on it ,right everybody?
Old Jan 14, 2009 | 11:10 AM
the stock bov is also recirculated to the icp. not just a cap. is this gonna cause and problems? also will it leak boost when i turn the boost up i only plan on running 21 or so. or will this not be a problem since i have the other bov? that may be a dumb question.
Old Jan 14, 2009 | 11:24 AM
wow if u think about it there is nothing wrong about it , if u wanna hear the woosh sound louder then take off the black bov and cap both sides , but i think there is nothing wrong whatsoever , i mean it was new to me and proabably new to alot of other ppl but id wait on a proffesianol to answer this jus to be on the safe side
Old Jan 14, 2009 | 11:29 AM
ok ill do that! My greddy bov sounds great right now. its pretty loud already but it has a great sound! The guy i bought the car from said a place called turbo tech did the work on the car so their is a chance they set it up this way. But he also could have did it himself since alot of people install their own intakes. I know on my previous cars i did.
Old Jan 14, 2009 | 11:32 AM
After this i also came up with something , my car doesn't start and i remebered that i took my stock bov out of the intake to make that woosh sound (my stock bov evo 9 MR/SE)and made a filter on the intake hole.....is that a reason y my car might not start?i installed a EBC greddy profec B and a turbo timer i worked fine and i missed around with it a lil more and it stopped starting sorry i knw off topic but wondering if any1 can help
Old Jan 14, 2009 | 12:08 PM
bump
Old Jan 14, 2009 | 02:29 PM
Slo_crx1's Avatar
Put the bov back into the filter the way it was stock. And please...from now on, don't touch your car anymore. I've seen way too many of your threads to see how the future of your Evo's going to end.
Old Jan 14, 2009 | 02:35 PM
Slo_crx1's Avatar
Now that I took a good look at your picture I see the hose running to the stock bov, but I see 2 problems. (A) The diverter valve is oriented backwards, and (B) it looks as if the vacuum source nipple is broken off the valve, and it's definitely not hooked up. It pretty much looks as if he just left the valve on there to plug both the intake return and the charge pipe feed. I can guarantee you that every time you shift your car is going mega-rich, and every time the idle drops when you come to a stop it's also doing the same. Also, I'm not sure why you'd want to waste the money on the Cobb Accessport when you can find someone off here to tune your car for much cheaper using EcuFlash and achieve the same results, but hey...it's your money.
First I'd worry about your UICP/DV situation.
Old Jan 14, 2009 | 06:13 PM
Thanks for the input. I think I am either gonna cap them or leave it the way it is. What do u think would be better? Anyone else have any ideas?
Old Jan 15, 2009 | 11:10 AM
bump
