Be careful when cleaning the throttle body
Old Jan 13, 2009 | 08:02 PM
shawnhayes's Avatar
Hey guys,
Tried to clean the throttle body on the car with spray on solvent several days ago. What prompted this was a sticky throttle that didn't respond to the cable being lubed (the throttle plate was sticking).
Difficult at best (although only detaching one screw was nice).
After the cleaning, the idle speed was off. Had to adjust the basic idle speed (needless to say, a pain in the butt).
So, take the throttle body off or use a cleaning cloth to clean the plate if the throttle body is dirty and sticking. This should save you significant time.
Good luck.
Shawn
Old Jan 13, 2009 | 08:56 PM
Evoryder's Avatar
i've cleaned my tb lightly with the tb on the car...no problems. You're right it's alot easier to clean off the car.
Old Jan 14, 2009 | 04:18 AM
tephra's Avatar
if I was taking it off to clean it I would redo the seals on the shaft...
Old Jan 14, 2009 | 05:18 AM
pls1968's Avatar
I had the Wynn's Fuel Treatment done and that was part of cleaning. Very highly recommended for those that haven't done it.
Old Jan 14, 2009 | 05:24 AM
pupo's Avatar
With evoscan you can set the SAS actuator and it helps when setting the idle, that is the way I set mine when I change the TB seals.
Old Jan 14, 2009 | 05:25 AM
pupo's Avatar
Check this thread: https://www.evolutionm.net/forums/ec...-sas-mode.html
Old Jan 14, 2009 | 05:30 AM
apagan01's Avatar
Originally Posted by shawnhayes
Hey guys,
Good luck.
Shawn
thats why lots of evo owners are using thins: we ship these all over the nation $15 shipped.
Old Jan 14, 2009 | 05:31 AM
apagan01's Avatar
pls1968, your car really responded well to the tratment,,,
Old Jan 14, 2009 | 05:47 AM
evoredy's Avatar
i think the TB needs a re-application of molybdenumnmn disulfide grease too lol. this might quell most sticking problems down the line. the OE grease was still there after 40K miles.
it this an integral step to finishing off the throttle body or does everyone just wipe it all off?
Old Jan 14, 2009 | 10:47 AM
Evoryder's Avatar
Seals should be changed when leaking which would be a 98% chance if over 30k, boosting 22+psi
Seals I recommend are Mil.Spec
Old Jan 14, 2009 | 01:44 PM
Ph3n1x's Avatar
I don't clean my throttlebody. It is automatically done by the meth.
Old Apr 26, 2011 | 08:53 PM
10isace's Avatar
Dumb question, but where do you apply this?
Old Apr 26, 2011 | 08:59 PM
awdturbo8's Avatar
Is it hard to repose the seals? Any right or wrong ways or tips to doing them
Old Apr 26, 2011 | 09:02 PM
prowakeskater's Avatar
Subscribed for interest
Old Apr 30, 2011 | 10:27 PM
awdturbo8's Avatar
Bump. I ment REPLACE the seals not repose. ^^^^^^^^ anybody ???
