MBC problem, help!
Old Jan 17, 2009 | 11:32 AM
Malik_EvoIX's Avatar
MBC problem, help!
alright it's a turbo xs mbc, i set it to 21 psi since i bought it back in April. (couple weeks ago it was like 30-40 degrees outside and it stayed at 21-22ish) so today it was like -7 and i am on the freeway heading to the movies to see Gran Torino (bad *** movie) in 5th gear doing a "pull" and the boost level stayed at 21 for a little bit, then boost started increasing to 27psi! WTF i did turned it down same thing happens! is the cold a factor contributing to this situation?
Old Jan 17, 2009 | 11:35 AM
Psquared's Avatar
yup..most likely. I'm not 100% familiar with the turbo xs but I imagine it's a ball and spring type mbc. It wouldn't hurt to dissasemble it and put a very light coat of oil on the ball bearing. I have heard of them sticking causing over boosting problems.
Old Jan 17, 2009 | 11:36 AM
silver_03_evo's Avatar
more than likely yes the cold is the issue with boost spiking
Old Jan 17, 2009 | 11:38 AM
i hope if the cold is the case ^^ if i upgrade to a EBC like apexi, will it fix my problem? i am not familiar with ebc's do they automatically adjust to the temperatures?! during spring summer this has never happened but then again here in Michigan it's like -10 right now!!
Old Jan 17, 2009 | 11:40 AM
idk bout the ebc i quit using mine when i was getting my tuned and have just used my mbc since
Old Jan 17, 2009 | 11:44 AM
my tune is set at like 21-22psi
Old Jan 17, 2009 | 12:04 PM
yeah my tune is at 31 psi the same mbc as you if you want controlable from in cabin get hallman but it is the cold
Old Jan 17, 2009 | 03:24 PM
nice i was just considering in upgrading to a EBC
Old Jan 17, 2009 | 03:28 PM
justboosted02's Avatar
its boost creep, your wastegate cant flow enough air around the turbine housing. its common when its really cold out. do you have an upgraded O2 housing?
Old Jan 17, 2009 | 03:35 PM
no i dont, but i plan to this spring, whate are the benefits of upgraded 02 housing, do i need a retune?
Old Jan 17, 2009 | 03:51 PM
bump
uncontrolled515
18
Dec 13, 2010 04:46 PM
purevo96706
Evo X How Tos / Installations
Apr 21, 2009 12:46 PM
drewblueeye
Aug 30, 2007 07:33 AM
fuzzychi
13
Dec 17, 2004 07:43 AM
EvilDylan
14
Nov 10, 2004 07:31 AM
