4th to 5th grind?
Old Sep 14, 2003 | 09:47 PM
AWDEVO8's Avatar
4th to 5th grind?
I was on int 290 tonight and some ratty wannabe Silvia ( 240sx) was messing with me. To make a long story short, he got smoked really bad. At about 100mph I shifted into 5th gear and heard a nasty synchro grind. Any body else had this problem? I think I remember seeing this as a problem a month ago somewhere on here.
Old Sep 14, 2003 | 10:03 PM
CweSt eVo's Avatar
yup..i have that problem..my evo is sittin at mitsu right now gettin checked out....those ****'s better fix it!!!
Old Sep 14, 2003 | 10:16 PM
evoinit's Avatar
i had thjat problem took it to my dealer and they fixed it its perfect now also had the recall done total process took 2 full days
Old Sep 14, 2003 | 10:17 PM
GoEVOGo's Avatar
I don't get a grind in the usual sense (where you hear the gears grind). But every time that I shift into 5th I can feel that it is not going in smoothly - feels like something (syncro or baulk ring?) is grinding.
Old Sep 14, 2003 | 11:07 PM
AWDEVO8's Avatar
Well, I can try to take it to mitsu but, I have a warranty block. I was just trying to see if I was alone in this prob. I know they have to fix it if it is a known problem even with a block on the warranty.
Old Sep 14, 2003 | 11:14 PM
Compjoc's Avatar
I had the grind too. They just have a kit for the 5th gear grind and it seems to do the trick. It took them 2 weeks to get the parts from the Mitsu. wearhouse, then about 3 days to fix it.
The service manager said that about 1 in every 5 evo's have this problem.
Old Sep 14, 2003 | 11:15 PM
superz's Avatar
beleive it or not I had the same bad grind going into 4th and 5th gear and after 2 days of beating the crap out the tranny on the track (roadcourse) it totally went away!!! I was ready to tear the tranny apart to see what was wrong. Something tells me that these trannys come very tight from the factory and all they need is some tough breakin-in. I have 6k miles now and she shifts beautiful!!
Old Sep 14, 2003 | 11:16 PM
AWDEVO8's Avatar
Anybody think they will fix it under warranty? You can see my mods.
Old Sep 14, 2003 | 11:20 PM
Compjoc's Avatar
They should, I have exaust and intake, but no AFC. They fixed mine, just stay away from the dealerships you know are jerks about mods.
EVO-Bill's Avatar
I used to have that problem with 4th but it just went away.
Old Sep 14, 2003 | 11:26 PM
AWDEVO8's Avatar
Bill, did you race a mustang on golf road tonight? I saw an evo just kill a black mustang!! It was great! thanks for the warranty block mitsu!
Old Sep 14, 2003 | 11:39 PM
EVO-Bill's Avatar
No my car hasn't been running for the last 3 weeks .
Old Sep 15, 2003 | 04:56 AM
SuperchargedGTZ's Avatar
my car is going to mitsu today for it.
Old Sep 15, 2003 | 07:44 AM
PocketAces's Avatar
I had the same problem--it turned out to be the syncrho. I am getting my car back today after a week of repairs. The part is on back order so good luck. Also, make sure they check out your gears while they have the tranny taken apart. One of my gears was loose on the spline and was causing extra wear so they went ahead and fixed that as well.
Old Sep 15, 2003 | 10:50 AM
EVOLUTION/RC51's Avatar
Same exact problem here.. 4th to 5th grind when fast shifting but after about 2000 miles, it's totally gone. Just needed some tough lovin!!!
