stock turbo w/ External wastegate
Old Jan 21, 2009 | 06:00 PM
Malik_EvoIX's Avatar
do i have to have a upgraded turbo for an aftermarket ewg? i have seen a stock turbo sti with a ewg, i want one and do i need a retune for this?
Old Jan 21, 2009 | 06:10 PM
chaotichoax's Avatar
do you want one just to say you have it?
yes it can be done on the stock turbo...a member did it but I can't recall his user name
Old Jan 21, 2009 | 06:11 PM
no not to "show off" if it can give me more power, and i like the noise it makes i was looking into this http://www.maperformance.com/tial-38...wastegate.html
Old Jan 21, 2009 | 06:20 PM
https://www.evolutionm.net/forums/4676249-post24.html
the cheaper easier way to obtain the same affect a lot cheaper would be an o2 dump which separates the wastegate from the turbine and dumps them
Old Jan 21, 2009 | 06:34 PM
sparky's Avatar
.....yes it can be done on the stock turbo...a member did it but I can't recall his user name
Also, RevMoto has just recently done one on the stock turbo and stock manifold. Personally, I think that this is overkill for the amount of exhaust flow passing through the a 10.5 housing on a stock 2-Liter motor. But, everyone is entitled to his/her own opinion. Whatever floats your boat!
Old Jan 21, 2009 | 06:39 PM
jmelocik's Avatar
Although the one in the post you referenced is not a stock manifold, it's a buschur manifold, that is a good reference. I machined a stock manifold for a guy to run twin 34mm external wastegates. Twin scroll requires two wastegates and since the buschur unit referenced above is an open volute, it only needs one. The guy I helped got them off of Ebay and wanted to be cheap so we figured out a way to machine the area for a mount flange and then did some welding and fabricating. The long runner side was fairly easy but the short runner side (driver side) was a little bit of a challenge. I'll check my external hard drive for some old pics and post them if I can find them.
Josh
Old Jan 21, 2009 | 06:40 PM
OhsixIXBish's Avatar
external wastegate wont give you more power? correct me if im wrong someone please i may be but if i can recall the only reason to upgrade the wastegate is if your turbo wont hold boost up top right? if you have the proper tune u shouldnt need a wastegate. i maybe be wrong dont hold me to it but im sure i read this somewhere.
Old Jan 21, 2009 | 06:50 PM
evokid511's Avatar
wow i was actually just thinking if this could be done haha i wouldnt mind ding it it looks kinda cool and to hve an EWG wouldnt be a bad thing haha
FrenziedTom
Apr 25, 2016 07:32 PM
stigmeister
26
Feb 18, 2016 09:23 PM
03Ev0luti0n
Aug 4, 2015 12:32 PM
2plaz
16
Apr 3, 2011 06:43 PM
