Did the dealer just called me a NOOB!
Old Jan 23, 2009 | 04:42 PM
Alex Rodriguez's Avatar
Another one for ya,
Since I am going back to Cali, what weight of motor oil should I use. Considering the mountains and hills compared to Florida's flatlands.
Also will that weight of oil be good for the cross country trip I am about to do next week.
ray3328's Avatar
The Guy you talked doesn't know wtf he's talking about... your correct
Old Jan 23, 2009 | 04:44 PM
btownsoccer22's Avatar
Originally Posted by Alex Rodriguez
Now I am getting that minor crunch in my shifting , i keep reading on synchromesh but everyone says Diaqueen for the tranny because of manufacturers specs.
Should I just stick with the diaqueen in the tranny or try that synchromesh tranny fluid
Lol when I said you got pwned I was jk, obviously you were right and the guy was just lazy or stupid or a combo of both.
Old Jan 23, 2009 | 04:45 PM
ak47po's Avatar
Go here bottom of page
http://www.mitsubishiparts.net/catalog/?section=575
Old Jan 23, 2009 | 04:50 PM
check
man i spent $50 on this gallon of diaqueen , they selling it for $36 on that website. I GOT OWNED, and i drove 1hr to get it.
Old Jan 23, 2009 | 04:55 PM
ak47po's Avatar
check
From now on get all your oem supply's from Mitsubishiparts.net. Russell will treat you right and if you have a question on anything he can help you out.
They are a vendor on this site.
https://www.evolutionm.net/forums/mi...ts-net-wa-238/
Old Jan 23, 2009 | 04:58 PM
Kracka's Avatar
My personal recommendation for the 5-speed Evo transmission is the Redline cocktail: http://www.maperformance.com/redline...smissions.html
I use and recommend the OEM Mitsu 90W DiaQueen in the transfer case and rear differential.
Old Jan 23, 2009 | 05:00 PM
Mr. PSSsSt's Avatar
FCOTM Winner
Try redline mt90 and u will notice a difference
Old Jan 23, 2009 | 05:05 PM
nawaz's Avatar
I been searching on the fluids and maintanance charts for a couple days because I am doing the 30k mile lube change. So I go to the dealer I ask for DIAQUEEN for my transfer case and rear diff. I tell him "Thats a gallon right", he says yeah, now I start to think i only need less than 2 quarts to do both yet I will have all of this oil to store away.
Before I even open my mouth to ask for my next fluid he says,"Thats plenty to do the tranny too!"
WTF! 1gallon of diaqueen to do the TC, diff, and tranny?
I tell him that the tranny fluid is diffrent its 75w90 and he says its the same thing.
So am I wrong ,I know the fluid charts has two diffrent pics of oil canasters .
So many people make mistakes in providing instructions. I would just double check it, that's all.
Old Jan 23, 2009 | 05:08 PM
Fusionr300zx's Avatar
hahahaha... wowwww
Old Jan 23, 2009 | 05:12 PM
GTijoejoe's Avatar
Originally Posted by EatSleepBoost
+1. i have never heard a negative thing about redline mt-90 and thats what i will be using in the built tranny i just got in the mail today
I used it for my 30k service in my tranny, rec. by Sheptrans, got rid of my 2nd gear grind after a while.... Using Diaqueen mits. fluid in all Diffs, also rec. by Sheptrans, especially in my stg II TC.
Old Jan 23, 2009 | 05:24 PM
Kracka's Avatar
The MT-90 is a bit thicker than Mitsu-spec which is why I like to mix 2 quarts of MT-90 with 1 quart of MTL. Redline recomends 1 MT-90 and 2 MTL, but I like to run a little thicker. It works great even at -20F and 100F+.
Old Jan 23, 2009 | 06:00 PM
awdwannabe's Avatar
Yep, I just had a clutch job done (Quartermaster twin disk) by Strictly Modified (both in a single review) and I used Redline MT-90 lightweight in the trans. and Redline shock proof in the tranny case, and everything is smooth as can be.
Old Jan 23, 2009 | 06:16 PM
is there diffrent kinds of redline 75w90
Old Jan 23, 2009 | 08:27 PM
RussellM's Avatar
Plat Vendor
They told you to put the same fluid in the TC, Diff and Trans
