Clutch or Transmission?
Old Jan 23, 2009 | 08:23 PM
pcamara17's Avatar
I live in ma and it gets cold down here and this is when it started happening. Well for the past couple of weeks when I go on the highway and goto my 4th or 5th gear and i accelerate harder it seems like my clutch is slipping but not fully sure its that. It feels like when I put a load on it it starts to take a couple of seconds to start kickin in. it could also be my transmission?
PLEASE HELP I NEED TO KNOW WHAT THIS IS!!!!
I know evos have some clutch problems; by the way I have about 60xxx miles on my evo 8
Old Jan 23, 2009 | 08:49 PM
tsi20gawd's Avatar
Clutch's tend to show there wear in cold conditions. If you are in a higher gear and you roll on the throttle and it feels like it's reving up a bit then kinda floats there until the drivetrain catches up you have a worn clutch. This is the best way I can describe how it feels.
Bryan
Old Jan 23, 2009 | 09:46 PM
blackblaze427's Avatar
clutch is on its way out
Old Jan 24, 2009 | 09:12 AM
pcamara17's Avatar
Thanks for the help. I was going to go get my car tuned next month, but I guess I have to get this done first
Old Jan 24, 2009 | 09:21 AM
nawaz's Avatar
Bryan
+1..............100% agreed.
Old Jan 24, 2009 | 02:18 PM
pcamara17's Avatar
if the clutch is worn shouldnt i be smelling a burnt smell
Old Jan 25, 2009 | 09:11 AM
ForcedFedRS's Avatar
Depends, you may have limited material left on the disc, so it will take a bit longer to get the smell to arise. Manual transmission do not usually hesitate when they have issues, auto transmissions usually slip when they have issues. It is most likely a clutch failing from what you are describing.
Old Jan 25, 2009 | 09:25 AM
gsr0801's Avatar
That sounds like straight clutch. The clutch is done.
