evo 7 compression
Old Jan 23, 2009 | 08:32 PM
dan81386's Avatar
evo 7 compression
does any one know the compression ratio for the evo 7 motor? the reason i am asking is because my 7 only boosts up to 15-17 psi max. and a stock evo8 is aprox 20psi would a evo 8 wastegate be an up grade? or even an evo 8 turbo? or would it produce too muck boost for the evo 7 motor?
thanks
dan
Old Jan 23, 2009 | 08:46 PM
tsi20gawd's Avatar
I am pretty sure the Evo 7 engine is the same 8.8.1 compression ratio as the 8/9 us models. I see no reason why 20psi would not be safe aside from the fact your ecu is tuned for 97 oct if memory serves me. You might want to consider a flash if you are planning on turning up the boost.
Bryan
Old Jan 23, 2009 | 08:49 PM
dan81386's Avatar
i was told that the evo 7 turbo was better than the 8 turbo because it has a titanium wheel and spools quicker is this correct?
Old Jan 24, 2009 | 12:20 AM
Yogi_B's Avatar
That only applies to the RS turbo, the GSR turbo still uses the inconel exhaust wheel.
Old Jan 24, 2009 | 12:24 PM
nitroboy158's Avatar
E7 workshop manual states 8.8
Old Jan 24, 2009 | 02:12 PM
Its a 7's Avatar
There made to run 95+ octane so hopefully you have some type of reflash for the gas over here. I run only Sunoco 93 octane and my boost is about 19-20psi with a reflash . Only the RS/RS2 have the titanium wheel but unfortunately we still have the small exhaust side.
Looks like the RS 7 turbo and a 10.5 exhaust side is what the evo6 TME turbo is.
Old Jan 26, 2009 | 07:19 PM
evo_gerard's Avatar
yeah it has 8.8:1 compression ratio
Old Jan 27, 2009 | 07:17 AM
dan81386's Avatar
thanks for the info everyone
Old Jan 27, 2009 | 07:19 AM
dan81386's Avatar
bang for buck is the 10.5 exhaust side a good improvement on the 7?
Old Jan 27, 2009 | 12:19 PM
28rRs's Avatar
quote!!
yeah pick up the 10.5 hotside, because with 9.8 and all and great supporting mods you dont having high boost after 5500-6000rpm! (for my experience!)
Old Jan 27, 2009 | 03:23 PM
dan81386's Avatar
ok thanks for answering my questions everyone
David Buschur
Oct 24, 2010 07:22 AM
project_skyline
22
Feb 17, 2009 09:08 PM
riceball777
164
Feb 14, 2007 10:05 AM
DynoFlash
87
Apr 19, 2006 04:40 PM
dlowman
12
Apr 25, 2003 03:04 AM
