TBE gaskets
Old Jan 24, 2009 | 08:37 AM
1evo2h8's Avatar
TBE gaskets
Ive had my tbe on my car for almost a year now and I need to remove the down pipe and test pipe, so if I do this am I gonna have to change the gasket from the o2 housing to the dp and the gasket from the dp to the test pipe? thanks!
Old Jan 24, 2009 | 08:50 AM
heel2toe's Avatar
It really depends on the condition of the gaskets when you remove them. Assuming they all arent torn apart you should be fine. You most likely have a donut gasket connecting your downpipe to your o2 housing and a regular 2 bolt flange gasket for the others. You could just buy them to be safe. Even if you reuse the old ones you never know when you are going to need a replacement gasket and they arent that expensive anyways. Oh and when you reinstall everything remember to use a gasket sealer and antisieze on all of your nuts and bolts. You will thanks yourself later.
Old Jan 24, 2009 | 11:01 AM
2plaz's Avatar
better to be safe than sorry. cough up a few bux and get some new ones.
werd
