**help please**
Old Feb 7, 2009 | 12:20 AM
DOUGLAS's Avatar
ok guys well i just read the last 2 posts and i'll follow through tomorrow and check into your guys suggestions......
Old Feb 7, 2009 | 11:00 AM
DOUGLAS's Avatar
ok so my IAT sensor is reading pretty accurate right now and I have yet to throw that code for the second time......my car would not start this morning once again so I unplugged the negative battery terminal to reset the trims.....I also unplugged and replugged the MAF, Cam Sensor, and it fired right up.....I let it run for 15 minutes and watched the diagnostics....my front O2 voltage is 5-6v?......i put the car in gear and back up a feet few in my driveway and it threw a CEL.....maybe because of the load?....so I turned the car off and tried starting it and it would not start....checked the codes and it was the cam sensor and crank sensor again.....
I also checked the honeycomb in the MAF it looks minty and the injector orings look a little dry rotted but nothing to be alarmed about....no visible sign of gas or anything
Old Feb 7, 2009 | 11:21 AM
sparky's Avatar
Will you provide a complete and detailed modlist to us please? Are you on the original stock fuel pressure regulator, or an aftermarket adjustable unit?
Old Feb 7, 2009 | 12:57 PM
DOUGLAS's Avatar
I cleaned up my initial post for easier reading and added a Mod list
Old Feb 7, 2009 | 05:57 PM
DOUGLAS's Avatar
anyone?......
Jared Murphy
11
May 15, 2017 08:45 PM
Eartears
23
Mar 1, 2017 11:53 AM
speifer
Jan 26, 2011 12:04 AM
Jean
Dec 13, 2008 09:17 AM
4G63>OOOO
29
Aug 16, 2004 06:30 PM
