Valve spring question for 280 HKS
Old Feb 1, 2009 | 10:22 AM
PHILLY EVO's Avatar
I just bought HKS 280 cams and wanted to know if I need valve springs and retainers. The car now has 100000 miles on it.
Old Feb 1, 2009 | 10:23 AM
Toddevo 8's Avatar
Yes, you will need to get new springs and retainers, because of the lift on the cams.
Old Feb 1, 2009 | 10:26 AM
WHTEVO's Avatar
Yes
Old Feb 1, 2009 | 10:27 AM
PHILLY EVO's Avatar
Thanks guys
Old Feb 1, 2009 | 10:29 AM
Steve93Talon's Avatar
Many people are running them on stock springs/retainers, including myself. They're pretty mild compared to other 280s, same lift as HKS 272s with alot less ramp rate than other big cams. Even some larger cams like the FP4Rs are ok on stock springs up to 8k.
Old Feb 1, 2009 | 10:30 AM
crazyevo4's Avatar
Would definitely suggest it due to the number of miles on the car.
Old Feb 1, 2009 | 10:35 AM
PHILLY EVO's Avatar
what springs would you prefer and would used ones be ok
Old Feb 1, 2009 | 10:42 AM
crazyevo4's Avatar
You could pick up a set of Brian Crower spring and retainer kit for $220.00. They would be alot better then your factory high mileage springs.
Old Feb 1, 2009 | 10:51 AM
Clutchdc5's Avatar
um....yes
Old Feb 1, 2009 | 02:25 PM
bao's Avatar
bao
gsc springs/retainers
Old Feb 1, 2009 | 08:37 PM
scheides's Avatar
EvoM Moderator
meh. Slap them in and go. These cams are so nice to the stock valve train, I wouldn't worry about it. If you ever have the head off, go with the GSC 5039 beehives.
Old Feb 1, 2009 | 09:33 PM
vboy425's Avatar
you don't no valve springs for hks 280 cams.
Old Feb 1, 2009 | 10:10 PM
94AWDcoupe's Avatar
factory springs are quite amazing. they test just like new ones do even with 100,000 miles on them. you dont need springs with HKS 280 cams. the profile is easier to follow than a stock cam. stock springs can rev to 9000 on stock cams so you can expect the same on the 280 cams.
Old Feb 1, 2009 | 11:17 PM
evovin's Avatar
Im revving 8550 on my HKS on stock valve springs
Old Feb 2, 2009 | 10:09 AM
mplspilot's Avatar
No need, unless you plan to rev over 8k.
