Bosch 1000cc injectors on an Evo
Sorry, this car isn't going to be here that long.
I've never had this issue on a Honda, waiting 52 minutes and doing the same thing seems irrelevant. If Hondas had this problem, i'd have seen it a hundred times. I guess you're going to have to take my word that it fires right up. lol
I will continue to add data as I come across it.
Idea's from some co-workers
Karl S. – leaky injectors (possible)
insufficient cold cranking amps from mini battery
MAP sensor problem (interesting... i think we all have different map sensors!)
(Senior Electrical Engineer)
Jin K. – we don’t have control over “rundown fuel injection” therefore you need a time based compensation for IPW. Jim said that “ALL OEM’s HAVE THIS”... I asked him what % of sure he was and he said 100%. (worked for GM/Chyrsler)
Jin thinks that the car is rich during starts and needs to be instrumented with an uninterrupted Wideband logging to prove this. Also seconded the need for a fuel pressure gauge.
Everyone want’s to know what hardware is on the car that runs fine vs. the cars that don’t run well. We need a COMPLETE LIST of everyone’s modifications.
Clarification needed: did the car with the good injectors put them in the car that wouldn’t start and vice-a-versa? Who put what in who’s car? Much detail needed here.
Can I get everyone to post up EVERY mod they have done to their car as well as vehicle info?
R/TErnie
2006 Evo 9 88950015
v5.10 Tephra Patch
Mr. Fred PSI based Boost Control
OMNI 4 bar MAP
AEM EBC solenoid
Walbro 255 HP pump
ID 1000cc injectors
HKS Green Foam Intake filter
FP intake tube
FP Red Turbo w/18psi actuator
3" TBE (no cat) rear o2 still in place.
AEM Wideband
FMIC
Magnus Intake Manifold
LICP and UICP
TiAL 50mm bov (vta)
Muse battery tray w/ Oddyssey PSC680 battery
STOCK LONGBLOCK (valve cover to oil pan... aka NO CAMS)
My ground strap on the intake manifold is still present
My ground strap on the Ground terminal is grounded to my mini battery.
R/TErnie
2006 Evo 9 88950015
v5.10 Tephra Patch
OMNI 4 bar MAP
AEM EBC solenoid
Walbro 255 HP pump
ID 1000cc injectors
FP intake tube
AEM Wideband
FMIC
LICP and UICP
TiAL 50mm bov (vta)
2. The table you want that you can select the step down of the ipw % - I made it all 100% - the ipw at start-up did not taper in the log and the car did not fire and when it did it was really sluggish from being to rich....dont wanna do that to many times - but I felt the need to test it.
3. I have my wideband wired in un-interrupted, its wired off ignition power so it keeps the voltage during cranking. Used a turbo timer harness and tapped in that way and I have a FP gauge.
4. Dan and I have not switch injectors that work in his car - maybe we need to but I thought the test of injectors not working on my car and then worked in his sufficed that its not injector related? At least we were satisfied ....
- FYI Dans car has ID1000's and starts 100% perfect - I saw it myself and started his car a few times......its starts correctly. He swapped in the set I sent back to ID into his car prior to shipping and they started the same as the ones in his car he claimed except they did not start in my car correctly - not sure what more proof we need? haha
5. My Mods
2006 Evo 9 88950015
v7 Tephra Patch
OMNI 4 bar MAP
GM 3-port solenoid
Walbro 255 pump (modded)
ID 1000cc injectors
Amsoil Cone Filter and Stock intake pipe (MAF version)
Amsoil cone filter and hard pipe (SD Version)
Zietronix Wideband
LICP and UICP
Odyssey PC680 battery
Stock Everything else......
SD Patch - Currently back on MAF.
Dans mods are the same except stock battery, stock IC piping, LC-1 wideband, and he is currently on SD w/ stock intake pipe and amsoil cone filter.
Guys I don't mean reduction of cranking pulse width by time cranking...
I MEAN... reduction in Startup IPW, Cranking pulse width etc. based on time since key off.
Jin explained it to me as that your ignition turns off, but your injectors still fire when you're turning off the car. This fills the cylinder and runners with unburnt fuel. After some time that fuel evaporates/condenses etc. His first language isn't English so it's a bit tough to pick up all he's laying down if you catch my drift.
I just spent the last several hours reading and trying to wrap my head around this problem, I have a thought that may be totally stupid and out in left field. What if the resistor pack mod was causing some sort of ignition problem? Some people may have inadvertently done something different with this portion of the swap to the ID1000's and have "lucked out" and gotten things right? What if it is a completely different system or set of sensors that is causing this issue? Sorry If I sound ignorant but it's 0345 in the morning over here in Afghanistan and I'm thinking so far out of the box I may be in the wrong shoe store!!! LOL
Josh
Josh
I thought of that Josh. Doesn't hold much weight though because the injectors work at all other times.
I removed the resistor pack and soldered all the wires together and then crimped it with a large copper end cap and then shrink wrapped the whole thing.
I got a go ahead on cutting up a stock intake manifold to hold the injectors for the spray test!
I'm bringing out the sawzall tonight
Josh
what about the idle stepper tables? Would a hot motor not want slightly more air than a cold one? kinda like an electronic choke to richen up the mixture when it's cold? what if you depressed the gas pedal slightly when trying to start it when having this "hot start" issue? I'm just throwing things out there now to see if anything rings a bell or tips someone off to something that may work.
Josh
Josh
I agree, i'm very impressed with what you guys know about the OE ecu.
Now it's just a matter of figuring this out.
Cranking pw info to come shortly from my Motec equipped car here. It's the 420A engine, but the data should still be relevant. Most engines are going to take a similar amount of cranking fuel. The important similarity is that it's got the same injectors in it.
I can bring my Evo IX down some afternoon if you want to play around with it. We could swap between the stock ecu and the m800 pretty easily as well to compare.
dammm im totally offtopic and sorry but
im having the same problem , just finished my build ,
and now my evo wont start , cause the injectors are not sparying , i have pressure cause i can see it on the fuel pressure gauge , but the stock injectors just dont want to spray
i checked
all conections , all sensors , ecu ,
but for some reason the injectors just dont want to spray the fuel into the cylinders ,
can anyone help out
i checked
can anyone help out
thanks for asking , nope my evo doent have aftermarket immobilizer , or factory either it was removed , i know if crank sensor dosent receive a signal , there will be no fuel out of injectors , so we tested that sensor and i was receiving its signal , somehow these injector dont want to **** in the cylinders
1. brand new pump
2. the fuel rail s going to explode cause i tried crancking some much and it build pressure on the rail and no injector has sprayed
3. some how there is no signal going to the injectors
1. brand new pump
1. brand new pump
