installed new clutch need advice
I just put in a stage 3 clutch (6 puc) and when im releasing to go into first the clutch pedal it shakes a bit till i get about 2000 rpm then it is smooth threw all gears. the clutch pedal goes in really easy and then when u let it out its real real touchy like there is like maybe 2 inches of release before its all the way disngaged. maybe i have to adjust the clutch pedal or what? or why does it shake and will it hurt anything?
in your other thread you stated you had all 3 acd lights on after install. I think in another thread you replaced TC fluid with royal purple.
Did you fix those issues yet. If not....you are headed down a bad and costly road my friend.
