Removing Cam Question
Old Feb 3, 2009 | 06:56 AM
EvolNinja's Avatar
Ok, I already have a HKS 264/272 in. I just purchased a set of 272/272. My question is, can I just take out the 264 and bleed the lifters or is it better for me to remove both and bleed all lifters? Another question, should I just use oil to lubricate it or should I use the assembly lubrication? Thanks in advance.
Old Feb 3, 2009 | 07:52 AM
EvolNinja's Avatar
bump anyone? I think I need to take this thread to the General area
Old Feb 3, 2009 | 08:01 AM
Kracka's Avatar
Just remove the 264 cam and bleed those lifters. Use engine assembly lube. Why did you purchase a 272/272 set when you already have one of the 272's?
Old Feb 3, 2009 | 08:19 AM
EvolNinja's Avatar
Because they don't usually want to sell just one of the cams. I will be selling the 264/272 once I got it out
Old Feb 3, 2009 | 08:29 AM
EvolNinja's Avatar
I didn't use assembly lube on my install of the 264/272. Is that going to be a problem? I mean, the car seem to run normal.
