Transfer Case probs I think. Help?
Old Feb 7, 2009 | 07:31 AM
FL_SilverEvo8's Avatar
Ok. I know my T-case is going because it is winny. But I am not sure if this is due to the T-case going or not.
When I am turning slowly forward or backward it sounds like my CV axles are popping. I am wondering if it could be from my T-case binding up or something? Or do axles tend to go out in our cars a lot? To me I think it is binding up or something. But would like to hear from someone that has had this happen to them.
Old Feb 7, 2009 | 07:34 AM
xspsi4's Avatar
Yup sounds like a t-case/center diff problem.
What erer you doing when it started making the noise?
Axles rarely go at your power level.
Old Feb 7, 2009 | 07:46 AM
EvoHung's Avatar
I have seen stock axles go out so don't rule that out. However, the whining is notorious for broken TCs. Does it whine in every gear? Does you steering wheel pull to the side by itself?
Old Feb 7, 2009 | 07:47 AM
I have been driving normal ever sence I started to hear the winning noises. If I had another car I wouldn't drive it at all. But I have to drive it I have kids to take to school and stuff.
Old Feb 7, 2009 | 07:50 AM
The car doesn't pull when driving it.
Old Feb 7, 2009 | 07:51 AM
How would I know if the LSD is going out?
Old Feb 7, 2009 | 08:07 AM
Nasty Evolution's Avatar
The only one front wheel would spin, or only the front wheel would spin.
As for the TC wine, it's not that hard to inspect it.. 1-2 hour job.
Old Feb 7, 2009 | 08:12 AM
justa4banger's Avatar
when is the last time that you changed your tc fluid??
might wana give it a try and change it..
Old Feb 7, 2009 | 08:18 AM
Yeah I am going to look in to doing that. I think it has been about 8 months.
Old Feb 7, 2009 | 08:20 AM
Huh???
only if the front wheel would spin or the front wheel would spin. you said it twice
Old Feb 7, 2009 | 08:22 AM
TurboRSX04's Avatar
how many miles in the 8 months?
Old Feb 7, 2009 | 08:25 AM
yellowevo82's Avatar
I see you have the exedy twin , some people get confused with the t-case whine vs this clutch making the noise. the exedy twin is pretty noisy clutch from the start. I thought my t-case was gone cause i heard constant whinning i just sent out my t-case to dan buschur and he said its in great shape. So just food for thought..
Old Feb 7, 2009 | 09:29 AM
I know that clutch is loud but it is really loud at 60 mph and the clutch noise is more like a clader at idle. So I know it is the T-case.
Old Feb 7, 2009 | 10:23 AM
JdMeVo4's Avatar
From what I've experienced there was also a slight vibration during acceleration when my xfer started whinning. The VC in mine failed due to overheating causing distortion blah blah.
Old Feb 7, 2009 | 11:40 AM
did it sound like a separated tire every once in a while?
