external wg hookup
Old Feb 12, 2009 | 10:05 PM
FastAzzEvo's Avatar
external wg hookup
I have an ebc and external wg... and need help with vac lines..
ok, coming from pressure side to bottom port on my tial wg to manifold... i get wg pressure.. which is good...
so then i implement a ebc solenoid...
i put top port on wastegate to one of the ports on the soleniod and the bottom port of wg to the other port on solenoid....===== i get infinite boost i believe.. let off gas at 22psi...
should of been 14 since i have it on its lowest setting..
what am i missing? i figure the later would be the proper way for solenoid...
anyways, this is a tial external gate and a greddy ebc...
I look at tial installation instructions and its pretty much what I have now, except the bottom port of wg that attaches to solenoid is T'd to manifold... so if that is the proper way.. why??? I will test this method tomorrow.
Old Feb 13, 2009 | 08:35 AM
20gmr's Avatar
you only use the bottom port on the WG
Old Feb 13, 2009 | 08:49 AM
FastAzzEvo's Avatar
Found answer..
bottom port to wg T'd one goes to NC port on EBC other end goes to compressor housing.. Preferrably before throttle plate.
top port of wg to COM port on EBC.
of course this if for a Greddy solenoid so others maybe different.
