ACD Delete / Removal ?
You may also be able to recoup some money by selling your TC after you swap in the replacement. Only issue is you need the money up front to by the replacement and there's no telling how long it will take to sell your used TC.
i have 2 pumps if u need it dirt cheap one out of a 05 and one out of an 06 there problem solved hehe but........
shep said he does the swap to not acd for i think it was 250ish im looking to go your way and have a big air duck or possibly rerunning my oil coolier there for my side exit exhaust
Yes it can be done the proper way. you need three peices from the non-acd transfer case.
the front peice of the inside carrier housing
The front non-acd cover.
The center non-acd housing.
I may be able to find some pics on evom.
I believe that if the lights are one, the front diff acts in open diff mode, but not sure.
So besides the obvious
-03-04 non acd transfer case
-pull pump and lines
Is there anything else needed to do in converting to non ACD evo? Will this throw a CEL? Do you leave the ACD computer plugged in or take that out too? Does the ECU need to be reflashed?
Basically what are the exact steps needed to transfer over to a non ACD system without triggering a CEL?
Would like to do the same I have an Evo 9 and my friends has a stage 3 shep t-case with 1500 miles hopefully he can sell it to me so I can remove all the b.s. And remove some weight and use it for a cold air
anybody else?? like can we get a step by step guide thats be proven/done before and worked for somebody? like mentioned above do we remove the acd computer and stuff like that?
i've been thinking of removing mines aswell, my acd pump has been dead for about a year..!
by just removing the lines and the pump will i be ok? or does something else have to be done?
