aps twin bov instructions
Old Feb 17, 2009 | 03:11 PM
FastAzzEvo's Avatar
Does anyone have them they could scan or give me a brief instructions on it..
Not the install, but mainly the adjustment portion of the bov.
Old Feb 17, 2009 | 05:38 PM
biggie5252's Avatar
I believe you shouldn't have to adjust it if you're running stock boost levels. If you're running more, do a boost leak test to a little above the pressure that you run and tighten the screw until it stops leaking (if it leaks to begin with). That's how I set mine. Someone may have a better way.
