Stock WG Pressure??
Old Feb 22, 2009 | 07:51 PM
aguita's Avatar
Stock WG Pressure??
how much psi does the stock WG holds? also how minimun of psi can I run with this WG?
diiirk@AwdMotorsports's Avatar
stock spring is 12 psi
Old Feb 22, 2009 | 08:29 PM
aguita's Avatar
yea I know...but I want to know If I run W/O boost controller how much PSI should I see?and how lower can I go on boost with the Boost controller
Old Feb 23, 2009 | 11:15 AM
1NastyMR's Avatar
lowest ull go is 12psi.... A boost controller helps your raise boost over wastegate pressure. If you want less then 12psi get a smaller spring for your wastegate, but then you will probably hold less at redline once you raise the boost back up
