evo engine with cam compression ?
Old Feb 23, 2009 | 03:40 PM
jdmstop's Avatar
Hi guys?
My friend want to purchase a used evo 8 with buddy club cams 264/272. However after performing a compression test by mitsu dealership;
the dry test show cyl 1 @ 115, cyl 2@ 125, cyl 3@ 105, cyl 4@ 125
Wet test # 133, 140, 125, 140.
The car has been flashed,running stock turbo, 255lph fuel pump, stock cam sprockets.
My question is, since factory spec engine compression is @ 163, is this engine in bad shape? Bottom line, is this evo worth purchasing?
Thanks!
Old Feb 23, 2009 | 03:46 PM
casper980's Avatar
subscribed, good question
wevo1985's Avatar
it sounds like bad rings, when doing a wet test the rings get oil on them and that makes a better seal causing the compression to go up. i had hks cams in my car and still had 165 across as well.
ISPEVO8
Feb 27, 2017 07:01 PM
lostsoulsevo
28
Feb 9, 2017 05:52 PM
Runker
Apr 26, 2016 05:23 PM
cantcatchme96
Lancer Engine Tech
Aug 22, 2008 12:32 PM
silverEVO8
28
Jul 6, 2004 03:16 PM
