ABS (anti-lock) Light on!!!
Old Sep 20, 2003 | 08:12 AM
Hooptie157's Avatar
Angry ABS (anti-lock) Light on!!!
Yesterday my ABS light came on briefly but went out so I thought everything was ok until today when it came on and won't go off. I called the dealership and I'm taking it in on monday to have it checked out.
I know it prolly only a sensor but it kinda pisses me off cause I've only had the car for 4000 miles. Where's the quality here? Also I've been noticing that my driver seats has been making creeking noises in right to left transitions and that pisses me off.
If these are the problems at 4k (along with crappy clutch and other creeks) what should I expect at 30k??
p.s. my integra type R never had any problems for 27,000 hard miles.
Hooptie
Old Sep 20, 2003 | 08:29 AM
sr20det91's Avatar
Did you get the car into any heavy water or mud?
Sometimes, the can muck up the sensor. My wrx used to throw the anti-lock all the time in the snow. I would just spray everything out and reset the ECU and it would be fine. Could be a bad sensor though.
As far as the seats creacking. There is another thread on that also. Do a search. They may have an answer for you. I agree the quality is definitly not that of a Honda, but really theres not a manufacture out ther that is.
Old Sep 20, 2003 | 08:30 AM
Honda98's Avatar
u had a honda...
now u got a mitsu
Old Sep 20, 2003 | 11:24 AM
Dale_K's Avatar
I know someone had the ABS light come on and it turned out to be a G sensor
"my lateral g-sensor died, which also threw a code for the right rear speed sensor. so they had to order a new g-sensor"
Old Sep 20, 2003 | 11:31 AM
nastea's Avatar
yeah that was me
Old Sep 20, 2003 | 11:42 AM
the evo wins's Avatar
weird....i was turning into my friend's neighorhood and all the sudden the ABS light when on and then it went off....the car almost stalled
Old Sep 20, 2003 | 01:23 PM
limey's Avatar
Have you changed the clutch line?
Old Sep 20, 2003 | 01:58 PM
Mister2zx3's Avatar
What is the g sensor for on the car? is it used by the braking system to determine if you're actually stopped or not?
Old Sep 20, 2003 | 05:51 PM
Dale_K's Avatar
Here is something from the tech manual.
Old Sep 21, 2003 | 12:05 AM
wow this is weird....last night the ABS light came on...tonight, my car wouldnt start i had to give it a jump....i bet this is related to that recall thing about the wires
Old Sep 21, 2003 | 05:54 AM
Dale_K's Avatar
Most car and bike electronics are sensitive to voltage levels. If it started with a jump I think you might have a bad battery or a wiring issue (ground?).
Old Sep 21, 2003 | 10:31 AM
should i take it to the dealer? will they care about my turbo timer that i installed with a harness?
Old Sep 21, 2003 | 10:34 AM
is it normal for a battery to die at 3900 miles?
Old Sep 21, 2003 | 10:43 AM
nastea's Avatar
no the battery shouldn't die. do you have a system?
Old Sep 21, 2003 | 10:47 AM
nope...i do have 100 watt high beam bulbs rather than the stock 55 watt but i dont drive around for hours with my high beams on
