Turbo oil supply line help please
Old Feb 28, 2009 | 04:45 PM
Timebombxxx99's Avatar
I posted this in a different theard to start with but no body could seem to answer the question so ill try here. Thanks for any information you have.
I am going to be running the fp red and i got a new oil supply line from them as well. I was wondering where else i could run the line from since it says on there website to rethink about running the oil supply line from the head for this turbo. This is right off forcedperformance website under the FAQs. Any ideas?
Q. Why do people say it's not good to get oil feed for the turbo off the cylinder head? Should I use a filter on my oil supply line to my turbo?
A. There are plenty of people who have oiled their turbo off the head and not had any problems, there are just as many if not more that have done it and had recurring turbo failure that was only vaguely described by the repair shop as "poor lubrication".
Oil pressure in the cylinder head on a stock 4G63 engine can be less than 5psi at times, while this may be enough oil for a factory 14b, T25 or even 20g it isn't enough to feed the high volume oil passages of the modified thrust setup in your FPGreen or FPRed model turbo. The Garrett severe duty 360 thrust setups also have an increased appetite for lubrication. Think twice before feeding either of these type turbos from the head.
Remember that you aren't just trying to keep some oil on the bearing, you are trying to float one piece of metal above another piece of metal on a pressurized film of oil, and at the same time keep the whole mess cool enough not to melt. A constant high volume stream of oil does just that, a measly trickle will send you back to the turbo shop.
One exception to this is the Ballistic Concepts Ball Bearing CHRA from Garrett. These turbochargers are totally different internally. Their operation is actually impeded by too much oil. It is fine to supply these turbos with oil from the head. In fact the oil line we offer comes from the head and features a .8mm orifice to restrict the oil flow to the turbo . These turbos require water cooling in the absence of the typical high volume of oil that would normally provide stable temperatures.
As far as filters go, you're damned if you do and you're damned if you don't. You shouldn't need one in your oil line. Failures occur due to dirt/grit in the oil making it into the turbocharger. Failures also occur due to plugged filters. We have seen it both ways. If you are going to use a filter, check it often. The most important thing you can do to avoid oil contamination of you turbo is to THUROUGHLY wash everything more than once before assembling your engine. Avoid sandblasting anything that goes inside or onto the engine. Specifically avoid sandblasting your valve cover. If you suspect that the machine shop that did your valve job sandblasted your head then make sure you remove the 4 plugs from each end of the head that cover the ends of the oil gallies and wash the gallies out with HOT SOAPY WATER. If you do this you will be amazed at what comes out of your beautifully machined freshly rebuilt head.
If you think all that is a bunch of crap, at least spin the engine over to prime the oil system without the turbo attached so that anything in the gallies has a chance to flush out instead of flush into your new turbo.
Old Feb 28, 2009 | 05:05 PM
Evolessfornow's Avatar
I answered your question. Same answer I got from people on the forum when I asked the same question a couple months ago. Call FP if you don't like the answer.
Old Mar 12, 2009 | 08:25 PM
TIGERJC's Avatar
bump
I have searched and couldn't find anything.
I also want to know where it would be better to run the oil feed line from and do know if the fp oil feed line will work with it?
Old Mar 12, 2009 | 08:44 PM
TIGERJC's Avatar
double post
BrownSuga
Sep 28, 2016 03:56 PM
Biggy VIII
Aug 9, 2016 03:06 PM
KennyRS
76
Oct 10, 2012 07:58 AM
Timebombxxx99
Mar 1, 2009 11:34 AM
nickracer9
Oct 31, 2005 09:37 AM
