Mivec oil feed line. Alternative oil pressure source.
Old Jun 19, 2016 | 03:46 PM
Biggy VIII's Avatar
Hi mates. I'm fitting mivec head on evo8 block and thinking about alternative oil source. I've read a few threads about tapping the oil sensor hole on the back of the block, feeding mivec from oil filter housing etc...
But I am running FP turbo and FP oil feed line, so my stock turbo oil feed port on the head is not used and just blocked. Can I use this stock turbo oil feed port on the head to feed mivec?
Old Jun 19, 2016 | 06:58 PM
LetsGetThisDone's Avatar
No, you need high pressure/volume oil for the MIVEC gear. The turbo feed at the head is not that. You need to use a port on the oil filter housing, or tap into the main oil galley...
Old Jun 20, 2016 | 03:04 AM
kikiturbo's Avatar
oil sensor hole on the back of the block is ideal
Old Jun 20, 2016 | 03:16 AM
Biggy VIII's Avatar
The block in already in car. No chance to tap the hole.
Old Jun 21, 2016 | 11:10 PM
RSMike's Avatar
Oil Filter Housing Bung would work wouldn't it?
Same as the FP oil feed line position.
Old Jun 22, 2016 | 12:23 AM
Biggy VIII's Avatar
There are two bungs AFAIK. One is used for FP line. Can I use the another one? Will it run fine without stock banjo bolt checkvalve?
Old Aug 9, 2016 | 06:39 AM
KITT2012's Avatar
I'm planningoing to do a bolt on turbo kit on my 4b12
Can you use an adapter where you can screw in where oil filter is?I've seen kits on ebay but I think you can find better.basically it's a block that fits onto where your filter is,it has two,male fittings for female oil line connecters and you can put in a 4612 filter like there isn't any problem. I thought this might be helpful,also,the Kit I'm talking about comes with an oil cooler which I thought would be useful if your turbo charging an n/a 4b11 or 17?
Old Aug 9, 2016 | 03:06 PM
Biggy VIII's Avatar
I decided to make a 3-port adapter - male 1\8npt + female m12x1.25 + female 1\8npt. That will make it possible to feed mivec and retain oil sensor in the same place, without tapping the block.
BrownSuga
Sep 28, 2016 03:56 PM
MRfabolous
Mar 11, 2010 12:03 AM
DIDYSIS
Apr 12, 2009 07:58 PM
Dus10
Sep 17, 2006 10:44 PM
silverofs
Sep 3, 2006 11:45 PM
