boost leak?
Old Mar 3, 2009 | 12:42 PM
ev0lution9's Avatar
Question boost leak?
im having a problem when going to neutral after being in a gear my RPMs drop and today i was sitting at a red light and my car sputtered and almost stalled. im thinking its a boost leak but i could be wrong. anyone have any input? and also how do i check i cant find anything on how to check it
Old Mar 3, 2009 | 02:49 PM
ev0lution9's Avatar
im trying to find out what it is if i rev it a little after im off the gas about two seconds later ill hear like a weird noise like air is being let out not a hiss though
Old Mar 3, 2009 | 02:55 PM
getsideways's Avatar
you need to pressurize your entire intake system from your turbo onward most people build their own basicly you need a cap to cover the turbo with a nipple on it such as youd find on a bike tire most use pvc pipe and use typical intercooler connector silicone hose to clamp it to the turbo inlet then you pressurize the system with a air comp. for those tough to find leaks use soapy water and spray it on your piping most aim to hit just over their peak boost i.e 22 psi having a buddy help you when doing this is a good idea its easier,,, and you should make it a regular part of maintainence every oil change or so
Old Mar 3, 2009 | 02:58 PM
EvoDom's Avatar
smoke test it......or just do what above me said
Old Mar 3, 2009 | 03:01 PM
ev0lution9's Avatar
but do the symptoms i told you describe a boost leak im not even sure if it is though i called iveytune today and they told me that it could be a boost leak
Old Mar 3, 2009 | 03:04 PM
http://www.dsmtuners.com/forums/arti...et-tester.html
there was a google search for boost tester if your lazy im sure someone sells them if you decide to build your own id suggest putting the filler valve on a 1-2ft piece of tubing as well as the guage so you dont have to peer next to your turbo inlet to see everything ,,, also when you test it all cars will slowly leak some of the pressure if you hit 20 psi and it stays there your doing great if you hit it and it drops immediatly you have some work to do
And yes it could very possibly be a boost leak like i said above you should be testing this regularly as they seem to develop overnight and can cause major issues
vr4gasmtt
Jun 14, 2015 10:12 PM
Adi489
22
Aug 14, 2013 02:18 AM
drewblueeye
Jan 17, 2007 02:55 PM
dbdude
15
Jul 4, 2006 10:27 PM
initialDRacer
Lancer Aftermarket Forced Induction Tech
23
Jan 31, 2006 10:23 AM
