Best 1000cc Injectors
Hey, I will be setting the car up for E85 this spring, I am looking for a good set of 1000cc+ injectors that will work well with the E85. I saw a thread about the PTE units possibly being affected by the ethanol so i'm not sure about those. This will be on a stock turbo 8 so the 1000's should be more than enough. What do you guys use and where can i get them for a good price?
PTE are PNP, but the Bosch are high impedance so you would need to remove the factory resistor pack and rewire stuff. Its not a huge amount of work, but definitely non a drop in deal.
If you want a large choice of injectors, just get some drop in. If you want an amazing injector, dont mind rewiring, and wont go bigger, get the Bosch.
I went with the RC 1,000cc injectors.
RC Engineering
Many satisfied EVO uses on RC's with E-85.
Check out the Alt Fuel subforum. Lots of good info there to get you up and running on on the race gas for the common man. (That's man as in mankind, which includes girlz and boyz. )
https://www.evolutionm.net/forums/alternative-fuel-225/
RC Engineering
I have RC injectors, no complaints, I have also used precision injectors, there are lots of good choices, just be sure to stay within well known and used brands and you should be good. You can always just use what your tuner recommends.
RC Engineering
RC Engineering
