any experience with V bands??
Old Mar 9, 2009 | 08:26 PM
mostH8D's Avatar
are these things prone to leaking? is it common?
i have carbon build up on every one of my v bands in my turbo kit. is this normal? if its not, what could cause this?
Old Mar 9, 2009 | 08:28 PM
Bggstin's Avatar
Vbands are superior to a bolt and gasket and should not be prone to leaking if straight. I'd check to make sure all of them are lined up perfectly as this can be a common problem.
Old Mar 9, 2009 | 08:30 PM
mostH8D's Avatar
here are some pics of the "leaks" maybe this is a normal thing?
what do you think?
Old Mar 9, 2009 | 09:38 PM
pekpekbuster's Avatar
I used to work on turboprop aircraft in the navy & we used v-band clamps on almost all our engine airflow piping.
Old Mar 9, 2009 | 10:48 PM
Evo_Hustler's Avatar
wow nice fact !...i guess it's true that you learn something new every day ; )... if the military uses it them it MUST be good
Old Mar 10, 2009 | 08:25 AM
mostH8D's Avatar
but what does that tell me? did they leak? is what i am seeing normal? more information please.
Old Mar 10, 2009 | 05:31 PM
I was implying that v-band clamps were better than for piping than bolted flanges.
But yeah, Bggstin is absolutely correct, it is a common problem. You gotta make sure that the pipes are lined up, & flush w/one another prior to tightening down the clamps. It's a b!tch by yourself sometimes cuz it really helps when another person tightens it down while the other holds the pipes in place, flush w/one another.
Old Mar 10, 2009 | 05:58 PM
justboosted02's Avatar
tighten down the v-band, hit it with a rubber mallet, tighten it down, rinse, repeat
Old Mar 10, 2009 | 07:36 PM
BluEVOIX's Avatar
Make sure you tap the clamp with a rubber mallet as you tighten it down. If you dont do that what can happen is the clamp puts force unevenly and that might cause leaks.
I dont know if they are prone to leaking, but they are the preferred method.
Skidonner90
Aug 1, 2016 11:02 PM
Ude Lose
Jul 17, 2016 05:53 PM
Howulikemyevo
Jun 5, 2016 10:24 AM
Howulikemyevo
Apr 15, 2015 05:25 AM
Hto Racing
31
Mar 6, 2012 01:30 PM
