Help! Brand New Engine Out of Oil!
Old Mar 11, 2009 | 01:15 PM
EvODavO's Avatar
were you checking the oil on a cold engine? try warming up the car and checking it again!
Old Mar 11, 2009 | 01:19 PM
casper980's Avatar
Originally Posted by 596736
I don't understand, did you miss a puddle of oil on the ground? You checked the dipstick and the oil vanished? There is a couple of obvious things going on here.
Edit: I'm sorry did you say you haven't used the car since December?
No, the driveway is clean, I am baffled too. I did notice the oil was getting low but it was still in the ok range, albiet right at the bottom, the day before I parked it. I parked it because I noticed the oil level had dropped, but I never noticed the car running badly. It had started snowing here so I decided not to worry about it and have been driving my other car since early december. It was nice out 45f and partly sunny, lol, anyway I popped the hood and was starting to clean the engine and decided to pull the dip stick just to see where it was at. I wiped it off, put it back in and it came out dry. I had just got the car back in my possesion after a year of it getting worked on, getting a new engine, and some other fun stuff. I was driving around and tuning it with the help of a couple of people that are very knowledgable of my ECU (Autronic). This tuning was only so I could break it in and was only into very low boost areas of the map, never in the higher loads. Got cold out then the above happened.
I know that engines can consume oil like /\ mentioned, but to that extent?
Old Mar 11, 2009 | 01:21 PM
casper980's Avatar
Huh?!? Yes it was cold, hasn't been started since december. But wouldn't there be some oil on the dipstick?
Old Mar 11, 2009 | 01:31 PM
EvODavO's Avatar
the oil level may raise when it is hot. different temps may give you different readings. I would warm up your engine completely until you hear the fan go on and then shut your car off and check the oil level.
Old Mar 11, 2009 | 01:45 PM
PVD04's Avatar
The oil level is not going to rise from nothing on the dipstick to normal just from warming up. I wouldn't start the engine until you add oil.
Old Mar 11, 2009 | 02:12 PM
EvODavO's Avatar
^ fair enough, just be careful because having too much oil in your engine may cause damage.
Old Mar 11, 2009 | 03:28 PM
andrewzaragoza's Avatar
Also make sure you use the correct oil weight for your engine. stock 4g63 engines would be 10w-30 but for built engines its typically 20w-50.
Old Mar 12, 2009 | 08:27 AM
vboy425's Avatar
so what was the conclusion ?
Old Mar 12, 2009 | 01:05 PM
casper980's Avatar
Posting a follow up tonight
Old Mar 12, 2009 | 03:37 PM
casper980's Avatar
Talking
Ok, so I checked out the car. First I opened the radiator cap and I didn't see anything No oil in radiator though thats good. So I slowly added oil and after two quarts it is perfect, right in the middle of the notches. I checked all around for leaks and I didn't see anything. Looks like it just burnt off, and the grim on the block is from driving. The radiator took less than a quart of antifreeze and was full. So apparently the oil pan can have 3 quarts of oil in it, and the dipstick can come out clean. I am going to change the oil and keep an eye on it. Hopefully it was just the break in period burning oil. Thanks for the replies everyone.
Is andrewzaragoza correct? 20w-50 for built engines?
