Getting ready to install my o2 dump
Well since I'm at it maybe I should ask if there anything else I should know before I start the install.
I picked up the o2 dump v2 local, waiting to get a used AMS LICP, gonna order the gasket from Q, DEI wrap for the dump. Am I missing anyhting?
search for the "how-to" and read up just so you are familiar with it. O yea, if you plan on removing your radiator, get replacement coolant, an 02 sensor socket, anti-seize, and some rust removing chemicals.
You guys are great, helping the OP out...thnxx...we have PM'd I'm getting him a gasket. However; BB you are correct since the flange is large and 5 bolts running without a gasket will work fine under good conditions, ie; hotside flange is flat, bolts are loaded correctly. We eventually started offering a custom high temp vermiculate gasket for our O2 Dump. The Webstore has a problem calculating anything with a small weight (1 lb and under). So we usually ask our customers wanting just the gasket to contact us for fast.accurate shipping...
thnxx guys again for helping out....EPM customers are the best
