my external wastegate on stock turbo!!
Old Mar 19, 2009 | 05:07 PM
  #106
joehoo's Avatar
wow this is the hate thread.
a little off topic but do you think a exhaust shop would re enforce the welds on a megan manifold?
btw good job on the whole set up
Old Mar 19, 2009 | 05:11 PM
  #107
scorke's Avatar
Originally Posted by evokid511
KKK??? haha
Turbo manufacturer, they make a lot of the VAG turbos, k04...
Scorke
Old Mar 19, 2009 | 05:19 PM
  #108
evokid511's Avatar
haha oo ok thats what he meant haha... and idk about an exhaust shop probably if they have a welder thy can its very simple to do so i dont see why not!!
Old Mar 19, 2009 | 05:29 PM
  #109
godmiller10's Avatar
Originally Posted by TTP Engineering
Those manifolds crack easily enough as is. It may not be long before it cracks from the added weight and vibration of the wastegate hanging off of there.
who gives a sh*t? it's not your manifold so idk why u care. The evo clutches tend to go, the engines sometimes break, trans sometimes break....get my point? **** does break sometimes. Just buy a new one...
nice custom job man!
Old Mar 19, 2009 | 05:31 PM
  #110
evokid511's Avatar
they crack if you dont reinforce it... i reinforced it so it wont crack but i get what you mean.. its not a big deal that they crack whoopie dooo haha
Old Mar 19, 2009 | 05:40 PM
  #111
sparky's Avatar
Yeah, evokid, that SLOW spooling KKK adapted by BMW from a light truck application gave just 8 PSI at the 6400 RPM factory redline. The IHI on the other hand, would give about 20 PSI by 3400. The car scooted as it only weighed 2340 lbs and had a close ratio, non overdriven 5-spd. Getrag GR. 2 tranny, a 300* Engle cam, and a ported head. We ran it on AvGas.
Old Mar 19, 2009 | 05:42 PM
  #112
evokid511's Avatar
wow thats crazy ive never heard of it sounds cool
Old Mar 19, 2009 | 05:47 PM
  #113
Cahst's Avatar
That is cool man. Are those hp and tq numbers at the bottom of your tag with the external wastegate and dump or before? Ether way that is thinking outside the box, and what we are all about.
Old Mar 19, 2009 | 05:57 PM
  #114
evokid511's Avatar
nope those numbers are before the ewg set up but will have new number of after when i go back home in a few weeks and thanks
Old Mar 19, 2009 | 06:00 PM
  #115
sparky's Avatar
Thanks, for putting up with an old timer, evokid...You can have your thread back now!
Old Mar 19, 2009 | 06:05 PM
  #116
evokid511's Avatar
haha dosnt bother me always cool to learn new info
Old Mar 19, 2009 | 06:35 PM
  #117
RevMoto's Avatar
Originally Posted by EvoDom
you should have just did two externals off the manifold. now that woulda been sick
would have looked like an hta set-up haha
but still good job man im looking into this more but looking at the twin wastegate
HTA doesn't mean twin gates. Also it has been proven that twin gates don't perform better than one.
Old Mar 19, 2009 | 06:41 PM
  #118
evokid511's Avatar
yeah i really cant see why two would work better then one if done properly!
oo yeah and for everyone who said its not a full twin scroll set up i just ordered my new mani and will be remaking the set up next week where it will look exaclty the same but be divided the entire way to the wastegate!!!
Old Sep 25, 2012 | 11:10 PM
  #119
andy2964's Avatar
Old thread yes yes I know. But I fail to see how this is going to decrease your performance. My thoughts would be that you are infact running safer because you dont run the risk of boost creep much if at all with a external wg. Boost creepy blows motors.
Secondly I lke the idea of a plate over the flap door. When the claims of decreased performance would be strictly told by a but dyno and/or theory. If you were to use a long enough dump tube (`5-8 inchs withas few bends as possible you are completely elminating the internal wg and creating a consistant pressure anywhere in you boost or load valuessince you dont have a flapper bouncing open and closed. Consistent pressure and dumped exhaust outside your typical exhaust system.....hmmm creates a senario to have a better VE, or that you have more flow by doing a setup such as this. Iv only reaally seen this done on SD setups and infact my own base model build (a DD that cost under 5K FTWhaha) Oddly enough I am using a similar manifold from speed corps It has a EGT port that I am welding the 38mm wg flange to and was going to weld the flap door itself shut but I have no recolection how or why I ended up on your thread but I really like the idea of a piece of steel to weld and seal it and possibly use some high temp gasket puddy merely for the extra security that it wount open and to keep airflow consistant and smooth instead of bouncing around on my crap weld skills (You think iv thought much about this haha). 8 inch home depot special dump pipe and I truely love the sound. Its subtle but loud enough to get a few second glances.
Well done and pretty innovative for a 19yo at the time. Im not trying to create a evo or even reach it with my build however this being the first time iv done a turbo build and learned to tune it should make the little daily driver a bit more fun for sure. Have a aquaintance that is currently "0"ing out his FT running 17psi on stock bottom end 4G94. Tuning excellence I would say.
Haters gonna Hate. Pioneering is a gift that not all can achieve.
Would love to hear follow up if you ever get back to reading this thread just to see how it went and if it is still going
Old Sep 26, 2012 | 05:37 AM
  #120
sparky's Avatar
Self-censored
