Best Turbo with 2.2L and E85
Old Mar 16, 2009 | 01:44 PM
Billy@EnglishRacing's Avatar
rebuild of there 6262
Old Mar 16, 2009 | 01:56 PM
ScorpionT's Avatar
People go back and forth on the rebuild issues for FP and PTE. I think a lot of it has to do with the people using them. Ive had quite a few PTE turbos on my cars and put them on friends' and pushed them hard and never had a problem, ever. Even on drag cars. Its not hard to kill a turbo by overspeeding, surging, oil starvation, etc... and I think most has to do with the tuner or owner.
Ive never owned FP turbos but Ive put them on a couple cars, never had a problem with those either.
Old Mar 16, 2009 | 02:04 PM
smp3000's Avatar
basically price wise the HTA3582 is between $350-400 more than the PT6262 - is it worth it? Strictly from a performance standpoint.
Old Mar 16, 2009 | 02:20 PM
ScorpionT's Avatar
Strictly performance standpoint, no.
Old Mar 16, 2009 | 02:21 PM
My personal opinion is yes it is. I would rather spend the extra 350 for the extra piece of mind. The turbo is not really something that i would think about from an economic stand point.
Old Mar 16, 2009 | 03:05 PM
RyuEvoIX's Avatar
Another vote for the HTA3582 with .63 hotside. That will keep you in the fun street able spool that you undoubtedly want and cover your power goal with room to grow as everyone eventually desires.
As for the intake manifold, I would stick with a ported stock intake manifold. I have had great success with mine as many others have. Just have to get it ported at the right place by the right people.
Old Mar 16, 2009 | 03:23 PM
smp3000's Avatar
Well if I have the money- I plan on throwing a magnus cast on there as my tuner is very capable of making it streetable. If I were to go the HTA3582 route with the built 2.2 don't you think I'd be able to spool quick enough wit hit being a .2 stroker? I was thinking of going with the .82 a/r for top end as .63 might allow too much back pressure. I don't know what the spool difference would be with this setup, but I also don't know what I'd be giving up top end wise by going with the smaller a/r...
Old Mar 16, 2009 | 03:26 PM
another factor in spool is whether your do a single scroll or a twin scroll.
Who are you looking to have build the turbo kit?
Old Mar 16, 2009 | 05:06 PM
ScorpionT's Avatar
The HTA82 would be a pretty quick spooler and for 600hp, the .63 would be fine. I generally prefer the .82, but it depends on the powerband you want. The Magnus manifold will also help the top end a little.
Old Mar 16, 2009 | 05:28 PM
Geoff Raicer's Avatar
Originally Posted by Evo8Emperor
If I was spending the money on a turbo kit there's no better way to go other than twin scroll. Better spool up times and transient response with the same power capabilities as their open volute cousins.
you got it
Originally Posted by smp3000
I'm interested in the above as well, but honestly I'd rally like to keep it a T3.
for a similar cost of a singlescroll T3 kit + hta turbo, another setup worth considering is a twinscroll t4 borgwarner 83-75 w/ 1.10 a/r...
for a singlescroll, the smaller a/r will offer slightly better spool and the larger one will give more top end with later spool (obviously). both have the plus/minus
for a twinscroll, you will always get good spoolup, yet with the larger a/r ratio you still get great topend... the best of both worlds.
Old Mar 16, 2009 | 08:56 PM
smp3000's Avatar
I know that the OEM is a twinscroll- but what makes a twinscroll setup? Clearly the Turbos that I'm choosing are single scroll... So what would be some turbos that are of comparrison in HP outage and twin scroll. And does this also mean the manifold must then be a twinscroll manifold?
Sorry- a little retarded when it comes to the "Scrolles".
Old Mar 17, 2009 | 02:09 PM
https://www.evolutionm.net/forums/ev...roll-work.html
^^^ start here
Old Mar 17, 2009 | 02:22 PM
smp3000's Avatar
Thanks Geoff!
I'm actually considering your manifold to base my build off of. Is it only for TS? Ir do you offer both options?
Old Mar 17, 2009 | 03:39 PM
thanks alot for considering our headers. we mfg both twinscroll and singlescroll headers to suit both styles of turbocharging. I personally prefer the twinscrolls as i have found it to be a much more driveable/responsive/satisfying configuration, but some of the drag racers on here prefer the singlescroll.
after you read through that link you may also want to look up some posts from "Ted B"
Old Mar 17, 2009 | 03:59 PM
smp3000's Avatar
I just haven't seen many evos go that route. I have some time to consider my options. I have an AWHP goal of 600 on E85 on a 2.2 built shortblock, built head, the ProEFI EMS, Kelford 272's, and magnus cast intake. I just want the most streetable build and fastest spool. I'm not looking to go 170mph- so top end is cool, but I won't really be testing out much further than maybe .5 mile going WOT.
Thoughts?
Geoff- you should check out my build thread on midwestevos- you'll learn a lot more about what's up with my build. http://www.midwestevos.com/forums/showthread.php?t=2595
