View Poll Results: Does your EPM dump leak?
Yes (explain if you know why ie reused old gasket)
31.58%
No (good for you)
57.89%
It did but it's fixed now. (explain how please)
10.53%
Voters: 19. You may not vote on this poll
Does your EPM dump tube leak?
Old Mar 17, 2009 | 07:37 PM
Evolessfornow's Avatar
How many off you have problems with your EPM dump leaking.
Edit: Sorry for the late info add. Wanted to get the poll up first. Exhaust leaks out of the dump tube at idle. Not sure if it is leaking around the turbine side or not. I used a new EPM gasket for install. I need to try adding some preload to my wga but I have a higher pressure wga.
Old Mar 17, 2009 | 07:38 PM
Smike's Avatar
Where is it leaking from?
Have you adjusted the WGA?
Old Mar 17, 2009 | 07:39 PM
kidwitevo's Avatar
its a dump tube, thought that was the point unless your wastegate door is actually leaking.
Old Mar 17, 2009 | 07:40 PM
sparky's Avatar
Are you running a turbine housing/dump gasket, or not?
Old Mar 17, 2009 | 07:44 PM
Used a new gasket from EPM.
hamx0r's Avatar
weird that issue only happens because people installed the stock gasket back...only other thing is to adjust the wga because it shouldnt be open at idle
Old Mar 17, 2009 | 07:48 PM
Ninja post edit. Lol.
Old Mar 23, 2009 | 12:01 PM
slow/ass/rs's Avatar
well if you used the stock gasket it would leak cuz the the gasket is open the emp is dived but that isnt the case then hmmmmm
Old Jun 1, 2011 | 08:43 AM
Stradag's Avatar
Mine leaks at idle with the fp black and fp 25 psi actuator. I preloaded the actuator all the way and it still leaks at idle and I can hear the flapper rattling. It's so annoying.
Old Jun 1, 2011 | 10:09 AM
06MREvo's Avatar
If you can hear it rattling you need to tighten the actuator more...You are using a divided gasket correct??
Old Jun 1, 2011 | 10:41 AM
SEEnoEVO's Avatar
^This. I am actually having one laser cut today from a high quality mr gasket material that I bought because the other one is poor quality.
Old Jun 1, 2011 | 12:29 PM
Evoryder's Avatar
I use copper gasket. The one provided is not good enough. If someone made one of OEM quality divided that would be ideal.
Old Jun 1, 2011 | 12:43 PM
ct9asilver's Avatar
http://www.maperformance.com/maperfo...og-ss-evo.html
Spray some copper gasket maker on each side and install, easy.....
Old Jun 1, 2011 | 04:09 PM
Craig King's Avatar
Have you contacted EPM?
Old Jun 1, 2011 | 05:12 PM
tweaker41's Avatar
I used copper spray gasket. Worked flawless for two years with no leaks.. The gasket that comes with it always seems to leak.
