bad wastegate maybe or something else?? (this car is driving me nuts)
Old Mar 18, 2009 | 10:20 AM
ekizenbe's Avatar
I searched before i posted this just so you guys know lol
Here is my problem, I ran a boost leak test a week ago and found some major leaks. I fixed them all and then took the car out for a drive. i had to turn the boost down to get back to my 22psi setting and wow the car had much more torque and power. This lasted for 2 days. I went to drive the car and it was slow again and showing 14-15 pounds or boost. First i did another leak test to verify that was good, it was, so i put the car back together and turned up the boost controller until i got back to 22psi. Even after this the car is slow like before. It does not have the torque it had for those few days. Could this be a bad wastegate actuator,turbo,or mbc?? The car has 62k on it. Also my afr is not consistent. I am tuned for an 11.0-11.5 and sometimes my wideband will show 10.0 through most of my midrange then it will go back to my 11's..other times it will show as normal.
thanks guys
Old Jan 21, 2010 | 01:01 PM
RevMoto's Avatar
definitely not a bad wastegate. You would either have high boost or not be able to build boost.
Ichigo0Soul
Mar 7, 2016 07:16 PM
Brandonm
10
Sep 12, 2015 10:53 PM
limaynard
Oct 20, 2013 12:34 AM
illogicalmind
Aug 22, 2013 01:38 PM
aggieEVO
20
Aug 21, 2013 11:02 AM
