Every time i **** quickly i hear a thump
Get the Beatrush rear differential mount bushing inserts and you'll be set! Cheap enough and 10 minute installation. Otherwise, if you want to go hardcore, get the Energy Suspension rear differential mounts; they're more solid but you will need to have the stock ones pressed out.
http://www.201motorsports.com/produc...cat=338&page=1
http://www.maperformance.com/energy-...shing-set.html
wow that made me laugh... ok back on topic, It has happened to me before also, I got scared but after some research here I found out evos do that when shifted hard/fast.... something to do with the driveshaft shaking and hitting something, but nothing harmful.... unless you really have something broken due to the bent trailing arm... get that arm and tire fxed first and then try again, if problem persist then it is normal, like I said before, it's a common thing with evos.
na i had the mitsubishi dealership look at it he says other than the bent control arm, (its honestly slightly bent), but bent none the less my undercarriage looks immaculate...that he doesnt see how just the arm got bent and nothing else got damaged...
uh... I think it is the driveshaft shaking hard when you shift like that, it could be the diff, or a combo of both, in any case I don't thing something is broke because you would hear it constantly and more like a grind, if you only hear it when shifting hard/fast and it sounds like someone kicked your fuel tank with a steel boot on, then it's normal, just shift slower/softer
yeah i found the control arm on ebay for 80 bucks, mitsubishi said it would cost 500+ (includes tax), and labor 200 = 700 just for that control arm, i'm a diesel mechianic so imma make this a project and post pics on howto's
