Cam Gears and Cams Questions!?
Old Oct 12, 2009 | 12:05 PM
  #31
Ludikraut's Avatar
I would never install a new set of cams without a set of adjustable cam gears to play with. Only if the best result ended up being a setting of 0/0, would I drop the stock cam gears back in. For example, I am very seriously considering finally upgrading from my HKS 280 cams to a set of Kelford 272s, but if I do so, then I will also have the shop run them at various settings ranging from +2/+2, +2/0, 0/0 ... -2/-2. Once I take a look at the accompanying power curves and spool characteristics, I will make a choice as to where to run the cams.
l8r)
Old Oct 26, 2009 | 03:07 AM
  #32
ItalianEvo's Avatar
X 100000000000
Who said cam gears are useless, simply doesn't understand how an engine works.
Old Oct 27, 2009 | 03:59 PM
  #33
JorgeYaHeard's Avatar
Originally Posted by ItalianEvo
X 100000000000
+1
Old Oct 27, 2009 | 05:42 PM
  #34
RSMike's Avatar
i'm trying to get maximum response and spool out of my kelford 272's.
i was thinking of advancing the intake, and retarding the exhaust to lower the overlap.
Has anyone tried this?
Cheers, Mike
