Spark plugs..
Old Mar 24, 2009 | 02:16 PM
F1fan07's Avatar
Spark plugs..
How often do you guys replace plugs? I just went over 30k on my EVO and I've had it for a couple months. I notice it sometimes idles rough and sometimes turns over with some difficulty. Is this because it runs so rich? I figure plugs are a good place to start with trying to sort out what's going on. Also, do you reccommend a certain type/brand or just stick with OEM?
Old Mar 24, 2009 | 02:20 PM
chaotichoax's Avatar
near stock stick with oem...30k will be my changing point unless I have an issue before that
Old Mar 24, 2009 | 02:23 PM
evo 9 guy's Avatar
I am at 45k and just changed my plugs again. But the first time I changed them was just to have some fresh ones for the tune. I just went with the factory NGK plugs ILFR7H if my memory serves me right. Might want to double check that though. I think it was about 25 a plug at the dealership.
Old Mar 26, 2009 | 09:20 PM
dambikeracer's Avatar
every 30k and use OEM
Old Mar 26, 2009 | 09:23 PM
djslik408's Avatar
Check your plug first before changing them. That also depends on your mod where you might need to change them sooner than 30k.
Old Mar 26, 2009 | 10:04 PM
SpinninAll4s's Avatar
25 a plug wow, I know where not to go to get plugs!
Old Mar 27, 2009 | 08:00 AM
rolly1818's Avatar
Registered User
i went a step colder with plugs - OEM replacement Denso IKH24s. it is gapped at 0.30 should i drop it to 0.25?
just a question lol.
Old Mar 27, 2009 | 08:39 AM
Evo8luva's Avatar
NGK BPR9ES, I can get about 6-8000 miles on E85, I normally change them when I change my oil. At a 1.70 a plug, why not.
Old Mar 28, 2009 | 09:50 AM
EGbeater's Avatar
I'm looking for OEM-type plugs that are two steps colder than original equipment for my IX... what is the heat range for the factory IX plugs? Is it 7?
I found colder-range NGK BPR7EIX and BPR8EIX that are iridium plugs - only $8.48 each (plus shipping) at sparkplugs.com:
http://sparkplugs.com/results_cross....8EIX&x=51&y=14
Will the BPR8EIX work on my Evo IX for big boost (up to 30 psi on E85) like the NGK R7437-8 plugs that AMS wants $41.52 for EACH?
http://www.amsperformance.com/cart/N...mance.com.html
Old Mar 30, 2009 | 07:41 AM
EGbeater's Avatar
Also, does anyone have any experience with using both the NGK BPR8EIX, and the Denso IKH24, which is also a one-step-colder iridium plug? Which one works better?
The IKH24 and IKH27 (2 steps colder) are both $11.99 each at sparkplugs.com:
http://sparkplugs.com/results_cross....KH24&x=43&y=15
Old Mar 30, 2009 | 07:53 AM
Mr. Evo IX's Avatar
I run the IKH24 plug, 25psi 93 octane, been in the car for over a year. No issues.
Old Apr 1, 2009 | 07:16 AM
EGbeater's Avatar
Okay, thanks for the feedback. A set of Denso IKH24 ordered for mine!
Old Apr 1, 2009 | 07:23 AM
wickdaddy's Avatar
cams, 680s, walbro, 24psi on 93 shell v-power.. running BPR7ES and change every oil change
Old Apr 1, 2009 | 09:23 AM
barneyb's Avatar
54k and running the plugs the car came with. Runs fine. I figure they will go past 60k.
Old Apr 1, 2009 | 09:57 AM
EGbeater's Avatar
Is your car running stock boost? If not, you might want to consider changing them a little more frequently. My IX only has 20k miles on it and I'm changing mine now just as a preventative maintenance measure (E85, 27-32 psi).
