Boost Issue
Old Mar 25, 2009 | 11:51 AM
boostinjuice's Avatar
Boost Issue
Boost was hitting 22 psi. Hallman MBC. Spring Mod. Holding to 18-19psi. Turned car off. One hour later, I cant boost past 14....
Old Mar 25, 2009 | 11:52 AM
TeStUdO's Avatar
Check your vacuum lines going to the boost controller. It sounds like you are hitting wastegate boost.
Old Mar 25, 2009 | 12:00 PM
Thats what I thought at first. But all my lines are connected.
Old Mar 25, 2009 | 12:48 PM
bad turbo? it has 90k miles on it
Old Mar 25, 2009 | 12:50 PM
DDATuned's Avatar
Try another boost controller.
Old Mar 25, 2009 | 01:22 PM
TeStUdO's Avatar
Check to make sure they aren't torn anywhere. If your turbo was bad, it would make a different noise than usual. Like Remy said, try another boost controller if the lines aren't damaged.
Old Mar 25, 2009 | 02:00 PM
Will try. Thanks
