I'm stumped!!
Old Mar 25, 2009 | 07:52 PM
ant_turbo's Avatar
I'm stumped!!
Recently my evo 9 has been running lean tuning did nothing,,, no matter what we did,,,So I replace new injectors new walbro 255 with new filter and regulator.... Still running lean,,,Im stumped,,,, What else can I check,,,
My mod's are
1000cc RC
HKS,272 EVO_9
WALBRO 255
3" Turboback
Injen UICP with Injen intake with HKS open filter...Stock LICP
Old Mar 25, 2009 | 07:54 PM
4G63K's Avatar
My mod's are
1000cc RC
HKS,272 EVO_9
WALBRO 255
3' Turboback
DAMN! thats a big turboback! ( sorry i had too )
Maybe those injectors are too big? Im not to great with this but are they scaled properly?
Good Luck
Old Mar 25, 2009 | 08:11 PM
def1's Avatar
vacuum leak?
Old Mar 25, 2009 | 08:15 PM
droppedrx7's Avatar
maf and/or map, tps sensors, oxygensor sensor too. any cels?
Old Mar 25, 2009 | 08:16 PM
droppedrx7's Avatar
bad gas could do it too, maybe you tune is for race gas or something
Old Mar 25, 2009 | 08:17 PM
evoseller888's Avatar
injector too big?
Old Mar 25, 2009 | 08:23 PM
ant_turbo's Avatar
Yeah I had them scaled by Scott @ RR. Reason for the 1000cc's was because the stockers where @ 100% Scott said upgrade to the 1000's which I did, now these are @ 100%. Something is wrong.......
Old Mar 25, 2009 | 08:24 PM
ant_turbo's Avatar
Tuned for 91 Octane, on 91 Octane.
Old Mar 25, 2009 | 08:26 PM
evokid511's Avatar
Good Luck
hahaha took me a while to figure out what u were joking abuot haha then realized it was a foot marker not an inch marker haha
Old Mar 25, 2009 | 08:29 PM
sparky's Avatar
Stock Mitsu regulator, or an adjustable aftermarket job?
Old Mar 25, 2009 | 09:18 PM
sikwititevo9's Avatar
check your throttle body gasket vacuum leaks and butterfly gasket those are really common to be bad from factory.....
Old Mar 25, 2009 | 09:19 PM
blownevo's Avatar
Maybe it needs to be retuned. They say 1000cc inj. r hard to tune properly with sotck ecu's.
Old Mar 25, 2009 | 10:03 PM
ant_turbo's Avatar
even with my stock injectors running lean!!! No VAC leaks ehter,, car idles fine,,,
It's just @WOT it lean out,,
Old Mar 25, 2009 | 10:23 PM
sprx19's Avatar
Was your tune messed with prior to this? Sounds like it isn't going into closed loop at fuel throttle and is reading the fuel scaling from a map it shouldn't be. But I'm also confused that your 1000cc injectors are going static, but yet the car is running lean. Is it knocking? Maybe you need a new wideband O2.
I also had a simliar issue in my subaru when a coil pack went bad. It was reading lean because the gas from that cylinder wasn't burning and was raw gas, therefore the O2 wasn't reading it. Said lean when it wasn't.
Old Mar 27, 2009 | 05:54 AM
4G63K's Avatar
lmao!
