o2 housing bolts!?
o2 housing bolts!?
the two 17mm spring bolts fell off my car?! where can i get some more of these?
when installing a megan o2 housing per say, do you need those spring bolt or does the housing come with it's own bolts to use?
as a temporary fix could i get some short 17mm bolts from a parts store?
I am not certain with the Megan, but some 02 housings come with their own hardware. You can source replacement bolts but the springs are seperate from the bolts. I wound up with 17mm m10x1.25 grade 9 (or 8 cant remember) The OEM bolts have wide collars on the head to seat the springs. Since you probably will not find that at a hardware store, just get some bolts and washers to hold the spring in place. I would recomend at least doubling up on the washers because there is a decent amount or torque going agains them when everything is all tightened down. You will need the springs though.
benIX
Jan 3, 2017 12:13 AM
02ES=>09RAL
Dec 19, 2013 07:24 PM
XtoEvolution
13
Dec 22, 2009 10:01 AM
EvoTio
Nov 6, 2004 09:01 PM
