Mystery Camshafts...Help Identify
Old Mar 29, 2009 | 04:41 PM
heel2toe's Avatar
I dont care to share who I bought them from. According to the seller they were installed in his car when he bought it. The previous owner told him they were HKS 272's So in the for sale section they were sold to me as HKS 272's.
Old Mar 29, 2009 | 06:25 PM
dsevo's Avatar
I'll go check my revolvers right now to make sure they don't have a 1 stamped on them.
Old Mar 29, 2009 | 06:34 PM
dsevo's Avatar
Nope, not Revolvers. BTW the lobes on my revolvers look WAY bigger than the ones pictured, but it could just be the angle of the picture.
Old Mar 29, 2009 | 06:48 PM
Murf's Avatar
I didn't think Revolver made cams anymore
http://www.revolvercams.com/
Old Mar 29, 2009 | 08:00 PM
dsevo's Avatar
I don't think they do, but just thought I'd check for the OP. Since he bought used cams, you never know. That would have been a pretty lucky find if he bought Revolvers thinking they were HKS though, lol.
Old Mar 29, 2009 | 10:26 PM
G20's Avatar
G20
from the pic it looks like a BuddyClub brand cam with is suppose to be exact specs as HKS.
Old Mar 29, 2009 | 10:43 PM
evoIXcencal83's Avatar
i have HKS cams. if they dont have HKS stamped into them then they are not really HKS.
Old Mar 29, 2009 | 10:45 PM
BLOX 272 are also an exact copy of the HKS
Old Mar 30, 2009 | 08:35 AM
GregGSC's Avatar
Messure them.. messuring the lift is the easiest.. grab a mic and the cam.
Here is how messure the Heal of the cam to the nose (peak lift to the bottom) and subtract that number from the base circle(90 degree's from the nose).. that will give you the cam lift. multiply that number by 1.73 (Rocker Ratio) and that will give you the Valve lift.
You should see something like .425" or 10.8mm of lift for the intake and .402" or 10.2mm Exhaust.
Here is what the Intake numbers of an S2 cam are. the base circle should be close with the HKS.
Nose to Heal (1.435)
Base Circle 90* of Lobe (1.180)
Rod Ratio (1.73)
Old Mar 31, 2009 | 07:06 AM
heel2toe's Avatar
I appreciate all of the advise everyone. Unfortunately I dont have a micrometer. But I will be going to a machine shop tomorrow to bring my head. Everything is disconnected from it however im just waiting for the de-tensioner tool. I will have the shop measure out the specs for me. When I spoke with him yesterday I was told they need to be measured in a special cam machine which they dont have. Thanks for all the advice and I will keep you guys posted!
Old Mar 31, 2009 | 07:21 AM
EvolNinja's Avatar
Originally Posted by JakeTheVIII
stock evo 8 cams are hollow too
+1 HKS Cams SHOULD have HKS stamped on the camshaft. I believe the cams you have is GSC1 cams? I remember GSC usually have series 1, 2, 3 and 4 cams or something like that. Sorry bro but I think you just got ripped off
Old Mar 31, 2009 | 07:29 AM
EvoDom's Avatar
im sorry but if the seller only said the previous owner "told" him they were HKS 272's i wouldnt have bought them, the seller really isnt at fault because he was selling them to what someone told him what they were.
my best advice brotha would be to do what greg from GSC told you to do. Measure the lift, and see if its the same as HKS says there 272's or 280's are.
10.8mm intake / 10.2mm exhaust.
wish i could help more lemme no.
Old Mar 31, 2009 | 07:34 AM
lexat20's Avatar
You can pick up a cheap caliper from homedepot for about 10 bucks. I'd follow the advice from Greg and measure them.
Old Apr 1, 2009 | 06:01 AM
GregGSC's Avatar
I don't believe from the pictures those are our cams... the lobes have a coating on them we do not run on the 4g cams we only coated 1 batch and from the picture it isnt the same coating.... I'm not 100% sure by the pic but from the looks i would say they are someone elses(not OEM for sure).
Old Jan 9, 2010 | 05:46 AM
todd6027's Avatar
I bought these cams from eric ,
both have 10.2 mm lift havnt done any other measurements yet .
